Pacific Alaska, California, Hawaii, Oregon and Washington
Pros/Cons Removing EGR Valve
Old Mar 19, 2003 | 12:48 PM
JD30thZ28's Avatar
Question Pros/Cons Removing EGR Valve
Hey guys just wondering if anyone has done this, and what they pros/cons would be? Thanks
Old Mar 19, 2003 | 02:02 PM
sleeperZragtop's Avatar
I removed mine, it will clean up your engine bay and from what Matt told methe internal of your motor will burn cleaner...when we were doing my cam swap I noticed black crap in the ports...almost like carbon...anyway it was easy to clean off. You won't pass aircare without your EGR from what I heard...it's an emission thing. I bought some polished block off plates from a guy off the LS1.com board..30.00 for the kit..that includes the AIR tubes.
Old Mar 19, 2003 | 02:29 PM
JD30thZ28's Avatar
Thumbs up
Cool Thanks
I have a low rpm stumble and I am sure it is the EGR causing it, so it must go and well it will help with my cleaning of the engine bay
Old Mar 19, 2003 | 02:37 PM
Draco's Avatar
I am not sure if the EGR would cause a low rpm stumble....
if you want you can use my spare vented opti and see if that cures your stumble before shelling out the money for a new one.
I assume you have already checked your plugs, coil, and wires for the stumble....
Old Mar 19, 2003 | 05:08 PM
Zedzag's Avatar
My 94 had a low rpm stumble that was caused by egr. It would stumble between 1300 to about 1700 rpm. I replaced the egr valve and it was fixed. Give it a try before your opti Johnny.
Old Mar 19, 2003 | 05:11 PM
JD30thZ28's Avatar
Yeah i am sure my Opti is still fine, only 23,000Km on the car. The stumble is in the low rpm range under 2,000RPM, and is only present at some times. I am thinking the EGR is sticking at some times. I hope it isn't the Opti
Old Mar 19, 2003 | 05:22 PM
Draco's Avatar
stumbling at or below 2k is a classic sign of a dying opti.... but it sure sounds young with only 28k on it. the thing is once the inside starts corroding its more a matter of age in years then it is mileage....
Old Mar 19, 2003 | 06:11 PM
AlexH's Avatar
Low rpm stumble can be caused by a stuck open EGR.
Pinging at higher rpm can be caused by a stuck closed EGR since the ECM advances timing when it thinks that the EGR is cooling the combustion.
Make sure you tell the ECM that you don't have EGR anymore (ie set the enable temperature to 255), or you might get knock.
Old Mar 19, 2003 | 10:52 PM
BPS's Avatar
BPS
I just removed my EGR for the same reasons - my opti has 4000 klicks on it but is 3 yesr old - I know i need to drive more
low rpm hesitation can also be knock related - a bunch of timing gets pulled and you bog for a second or 2.
JD I also pulled my AC last month - looks like were thinking alike.
Old Mar 19, 2003 | 10:54 PM
NiteRider's Avatar
Took mine off and bought some block plates. Can't complain.
Old Mar 20, 2003 | 01:43 AM
bunker's Avatar
stuck open egr causes rough idle & stumble, also causes the blms to be lean, its a vacume leak period.
Old Mar 20, 2003 | 02:06 AM
LuCiFeR97Z28's Avatar
Just curious - wouldn't the EGR removal throw a code?
Old Mar 20, 2003 | 03:51 AM
Ya, but I'm not concerned..we have the resources
Old Mar 20, 2003 | 10:38 AM
Mr Z28's Avatar
When you remove it, take a look inside of it and see if it is carboned up. A lot of people clean their EGR's and put it back on if they have been sticking shut / open.
Let me know how it goes, because my 97 has 11,000 kms on it and I have the same stumble at low rpm's and it makes for a bit of a rough idle as well. I doubt it could be anything related to corrosion in the opti as previously mentioned, as my car has never seen a drop of water form rain or being washed.
Old Mar 20, 2003 | 11:28 AM
JD30thZ28's Avatar
I'm OBD1 I will leave it to Payam or Matt to work on the tune Some people have done it and have had no codes. OBD2 would definately throw up an "SES"
I will be pulling it on satruday morning, I will let you know if it resolves the issues.
dfarr67
Apr 10, 2015 07:44 PM
edman
Mar 13, 2015 09:39 PM
97SSdude
Dec 31, 2014 07:43 PM
jocamino
Dec 29, 2014 10:15 PM
