Cam in a 94 LT-1
Old Mar 17, 2003 | 09:09 PM
94FlamdS10Blazr's Avatar
Cam in a 94 LT-1
Ok i got a 94 Caprice motor going in my 94 blazer and wanna do a cam also. Whcih one do you think Ill need? Its got a Granitelli MAF, Hedman headers, 2400 B&M stall(the guy at Summittalked me into it when I said i was going to get a cam), flows, 3.73 gears,LSD, and all MSD ignition.
Whats the ins and outs of the cam in this? Which one to get?What do I have to worry about? thanks for the help guys
Old Mar 17, 2003 | 09:31 PM
twells's Avatar
what do you want out of the car? what are your goals and what purpose will the car serve. think about those questions when picking a cam for your lt1
thomas
Old Mar 17, 2003 | 10:23 PM
neil350's Avatar
LT4 Hot Cam kit and tunning, that sounds like a good cam for you.
Old Mar 17, 2003 | 10:38 PM
goal for the truck are to match up to the other stuff I got and not throw codes or not work with each other. Other goals, to beat mustakes!
I was thinking the hot cam myself. Are there any other ones on the market that match the specs for cheaper? or do you know the specs and Ill match em up? Where do I get a LT1EDIT for this setup?
Old Mar 17, 2003 | 10:44 PM
Smokn '94 Z's Avatar
Lightbulb
You can find others that match the specs of the Hot Cam but if you do the kit I doubt you will find cheaper.
How about a custom grind?
Call some cam companies....(Crane/Comp) & tell them your plans. They might be able to steer you in the right direction. Then compare the cam they suggest to the Hot Cam.
Good Luck
Old Mar 17, 2003 | 11:32 PM
danz28123's Avatar
Do you need to be able to pass smog? If so that will limit your selection a little. If the car will be driven daily or if it is just for weekends/fun should also be considerred. Good luck!
Old Mar 18, 2003 | 01:02 AM
f*** a smog test! I live in Louisiana and dont see us getting a smog test soon
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Sergio
Jan 27, 2016 04:27 PM
kksi
Feb 16, 2015 06:49 PM
sskevinm
Dec 18, 2014 11:16 AM
