Changes to the Z28 / 98 and up
Old Mar 17, 2003 | 12:18 PM
Sal Collaziano's Avatar
What changes were made to the Z28 from 1998 and newer? Interior? Exterior? Drivetrain?
Thank you...
Old Mar 17, 2003 | 01:01 PM
Black01_Z's Avatar
98 and 99 had the 5 spoke wheels, in 2000 they switched to the current 10 spoke wheels. In 2001 and 02 they got an LS6 intake, a slightly stronger cam and no EGR. Interior has stayed the same and really depends on options.
Old Mar 17, 2003 | 01:05 PM
Thank you very much.. I guess the wheels are easy to change if that's what you like. How much power did the other options add? Sounds like you could update those as well if needed...
Old Mar 17, 2003 | 03:28 PM
stik6shift98's Avatar
other options added maybe 10 hp
Old Mar 17, 2003 | 04:01 PM
Ken S's Avatar
99 the switched over to slightly smaller fuel injectors. I think the valve covers bolt on differently than 98.
2000 I believe the went to cast iron exaust manifolds
Umm, I think in late 2001, 2002 all LS1's get the LS6 clutch and pressure plate, which is a tad stronger. This is now the stock replacement for all LS1's..
The 2001's have a bit more low end tq, and supposdily because of the ls6 intake, they keep the same peak hp..
Old Mar 17, 2003 | 04:07 PM
99blackSS's Avatar
98s and up have a bump on the passenger side of the floor which is for the V6 cat. but is still on the V8s.
Old Mar 17, 2003 | 06:00 PM
LT1's Avatar
LT1
The 93-97 has the same hump in the pass. floorboard.
Old Mar 17, 2003 | 07:30 PM
98=28lb injectors
99/00/01=26lb injectors
02 28.5lb injectors
not sure bout 01 so i just took a guess
Old Mar 17, 2003 | 09:24 PM
psychocabbage's Avatar
10% of 2001 and 25% of 2002 have the LS6 blocks.... which evacuate downstroke air to adjacent chambers.
Old Mar 17, 2003 | 09:29 PM
lol that ls6 block thing has brought about just troubles....
i get ims telling me omg i know why my car is soo fast i have an ls6....im like lol......right.....
ls6 block does nothin no hp gain not a ls6....no internals
Old Mar 17, 2003 | 11:55 PM
99blackSS's Avatar
Just kidding
Old Mar 18, 2003 | 01:07 AM
i never said any power gains.. just the benefit you gain from that block.. i need to lift the car to know 100% for sure.. we shall see tho.. doesnt really matter but its just a kewl "what if" if you do have it.. ya know?
Old Mar 18, 2003 | 10:25 AM
XH2Oskier's Avatar
Question
99 and newer have slightly larger gas tanks, don't they?
Old Mar 18, 2003 | 12:50 PM
ya or an easy way to find out is to see if there is a bulsleye on it or not....or u can see by the produt number.....
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Renegade Toker
Jan 23, 2015 10:27 PM
NewsBot
Jan 11, 2015 06:10 PM
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
