Fuel pressure safety switch and window switch...
craigffb
03-17-2003, 11:22 AM
Anyone running both? I so hw did you wire it? Can they be wired in line or will it not work that way??
stik6shift98
03-17-2003, 08:49 PM
i think 1 of those is fine....
i have fpss
i know ppl have done both b4...im guessing wire them in line
craigffb
03-17-2003, 09:16 PM
i have fpss
That's what I'm thinking too, but I'm not sure if they would cancel each other out. I would think so. Anyone:confused:.
stik6shift98
03-17-2003, 09:29 PM
hmmm good luck u got me on that one too:confused:
Blue89Bird
03-17-2003, 10:21 PM
the fuel pressure safety switch has one end that gets connected to the relay, the other end gets grounded. the ground from the solenoids is what gets connected to the window switch.
craigffb
03-17-2003, 10:30 PM
Ok, I think I've got it now. Does this sound right?
NX relay:
Red to WOT switch
Black o 12 V
White to FPSS to ground
Green to solenoids
MSD:
Black to ground
White to tach lead on Accel 300+
Red to 12 V
Yellow to solenoids ground
Now is it right:confused:
stik6shift98
03-17-2003, 10:39 PM
sounds good to me!:D :D
just wait till a couple more people reply to make sure...
craigffb
03-17-2003, 10:43 PM
That's what I hope will happen:D
Blue89Bird
03-18-2003, 09:19 AM
looks right to me as well
95greendragon
03-18-2003, 10:08 AM
I know that White to FPSS to ground is correct and I am 99.9 percent sure the rest of it is correct.
phil46y
03-19-2003, 12:17 PM
Here's a link to the wiring schematic I used; Hope it'll be of some help.
http://temp.corvetteforum.net/c5/rwj383//singlestagenitrouswiring2.jpg
craigffb
03-20-2003, 12:12 AM
That one is useing two relays, which I hadn't planned on doing.
Drew778/94Z
03-20-2003, 01:19 AM
Just put both on the side, they just add more weight. :D
Thats why I just left that safety stuff off. :eek: ;)
Just waiting for the big BOOM now, maybe the 150 shot will do it.
:p
craigffb
03-20-2003, 02:19 AM
:p
Your nuts and my car is old:D. I should have all the stuff soon. You gonna help me put it in?
Drew778/94Z
03-21-2003, 12:46 PM
Yep!
Maybe I'll put some safety stuff on my car. ;)
craigffb
03-21-2003, 04:08 PM
Yep!
Get it and we'll do it at the same time.:p
And I still need a pice of wood. :mad:
