Delco Changer Compatability & wiring question
Old Mar 16, 2003 | 09:38 PM
rlax31's Avatar
I have the Delco 12 disk changer I took out of my 97. My buddy has a 2002 Z28 with the Delco CD HU, but no changer. Will the changer work with his HU, and where would I get the wires to hook it up??
Old Mar 16, 2003 | 09:43 PM
stik6shift98's Avatar
prob need to go to gm
Old Mar 17, 2003 | 10:27 AM
BandDirector Blk98ZM6's Avatar
It should work without any problems and actually, the '02 TA is also already wired for it. Look behind the driver side, back hatch trim panel and you'll find a wiring harness taped up back there. Undo the tape, plug the connector into the changer, and everything should work just fine. If doesn't, pull the HU and make sure the changer wiring is plugged into the HU as well.
Old Mar 17, 2003 | 06:26 PM
rlax31's Avatar
that would be awesome, then all I'd have to do it mount the be0tch
nophix
Nov 30, 2014 10:26 PM
FlyByFormula
Aug 21, 2002 12:05 PM
30thZ286speed
Aug 3, 2002 04:54 AM
Geoff Chadwick
Jul 31, 2002 12:07 PM
Paulberg
Jul 26, 2002 11:35 AM
