Oil cooler removal?
Old Mar 16, 2003 | 07:14 PM
jasons93z's Avatar
Question Oil cooler removal?
How do u do it? Thanks
Old Mar 16, 2003 | 08:19 PM
gb95zconv's Avatar
Drain thr radiator or rig yourself som sort of plug for the hose you have to remove. Remove other hose from WP. There is one bolt that holds it to the block midway back. After you take that bolt out move back to the oil filter area. Youll find a bolt between the 2 metal cooler lines....take that out and then wiggle the line assembly out....slide it out towards the front. Remove oil filter...look up inside the filter adapter and youll see a big *** nut....losen that and the whole cooler adpter will come out.
Old Mar 16, 2003 | 08:42 PM
jasons93z's Avatar
thanks
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
BigWil
Mar 29, 2015 12:24 PM
94Z28LS1toLT1
Parts Wanted
Jan 21, 2015 04:37 PM
97 RedSS
Jun 10, 2003 07:58 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
