Car not running right after hotcam install
Old Mar 16, 2003 | 06:51 PM
ollie-99's Avatar
it feels like i have no power, driven about 10 km and exhast goes till the y-pipes and its open from there
also i did an OBDI conversion and didn't swithc the knock sensor could that be causing the problem?
Old Mar 16, 2003 | 07:10 PM
InGodITrust's Avatar
Are you 100% sure you have the firing order right? I had a similar problem after my cam swap! Had the firing order wrong even after double checking it!! Double and TRIPLE check the order!!! Just my 2cents worth!! Good luck!
Old Mar 16, 2003 | 07:20 PM
96cam4ro's Avatar
I also felt no power with the exhaust leak right after the cam install..reinstall your y-pipe and I'm sure you'll notice something.
Old Mar 16, 2003 | 07:51 PM
gb95zconv's Avatar
A couple of things To suspect.....timing off a tooth or rockers not adjusted right.
Queens94z28
Dec 20, 2014 09:11 PM
Dec 4, 2014 11:56 AM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
Snake Slayer
Jul 29, 2002 12:39 PM
