ExMustangOwner
03-16-2003, 06:55 PM
Any one help me mount my fuel + nitrous solenoids, and WOT switch? I have a 2001 LS1 with a Strut tower brace. I hear that helps. Thank you all so much :)
Problems finding a mounting point for my solenoids and WOT switch.ExMustangOwner 03-16-2003, 06:55 PM Any one help me mount my fuel + nitrous solenoids, and WOT switch? I have a 2001 LS1 with a Strut tower brace. I hear that helps. Thank you all so much :) stik6shift98 03-17-2003, 10:00 AM mount your solenoids on the drivers side...way in front....and the wot switch goes behind the throttle body so that the little needle is directly behind the part the throttle stop thing hits when it is wide open Mikael 03-17-2003, 11:17 AM http://66.43.184.45/hidden.htm I put the solenoids on either side of the intake under the air silencer, and the WOT switch inside the car hose clamped to the steering shaft. Very hidden, and easy to do. stik6shift98 03-17-2003, 08:47 PM i hope no one ever takes your lid off...then its not sooooo hidden ExMustangOwner 03-18-2003, 11:34 AM What bolts, nuts come with the kit? Anyone have any pictures? I bought a used kit and just have the solenoids and brackets. Do I do any drilling? I don't care if it's hidden or not. stik6shift98 03-18-2003, 05:58 PM Originally posted by ExMustangOwner What bolts, nuts come with the kit? Anyone have any pictures? I bought a used kit and just have the solenoids and brackets. Do I do any drilling? I don't care if it's hidden or not. yes u will most likely do some drilling to keep the solenoids in place ExMustangOwner 03-19-2003, 02:51 PM Ok that's what I was wondering. Any more pictures or last minute mounting points? Thanks again. Weather pending, I'll probably do the install this weekend. Zippity'Z 03-20-2003, 08:25 AM The WOT switch goes on the throttle body to activate when it's at wide-open throttle. You can see some pics of them mounted on this page http:/www.jimmy-jams.com/activationswitch.htm *R | ||
