feels like car is missing
Old Mar 16, 2003 | 12:08 PM
bachehbad's Avatar
Ok i just got my fuel filter changed and my spark plugs changed, when i am cruising i feel tiny hesitations or jerks in the car, I have only driven the car maybe a distance of 5km after the stuff was changed, will this go away or should i go back to the mechanic?
Old Mar 16, 2003 | 01:18 PM
tkatchev69's Avatar
That's exactly how my current problem started out! And now it has progressed to when I step on the gas, it sort of shakes without going anywhere for a second, and then all of a sudden, the car takes off. I did the same work on my car, trying to eliminate the small things. My next guess is fuel pump? Any thoughts?
Old Mar 16, 2003 | 01:20 PM
bachehbad's Avatar
**** so the problem is only going to get worse?!?!
i dunno what it could be!! someone help!
Old Mar 16, 2003 | 01:23 PM
Twice The Fun's Avatar
try plugs and plug wires....mine did this, and i replaced the following
  • opti
  • MAF
  • intake elbow
  • blocked off EGR
nothing helped, doing plug wires soon...
Old Mar 16, 2003 | 01:46 PM
bachehbad's Avatar
so your saying replacing those components didn't do anything???
why would this happen after i throw in new plugs and a new fuel filter?!? i just don't get it? This happened just after i changed the plugs, could the fuel filter not be on correctly????
Old Mar 16, 2003 | 01:49 PM
Rodrigues's Avatar
I had that as well and my car was running very rich, is your fuel consumption really bad?
Old Mar 16, 2003 | 01:54 PM
tkatchev69's Avatar
I suspect I'm running very rich, based on the soot on the inside of the tail pipes. I ran a container of Seafoam through, just to help clean the fuel system, but didn't notice anything different. I tried the gas "dryer" also, in case there was some water in there. Any other thoughts?
Old Mar 16, 2003 | 03:01 PM
LS1_03's Avatar
Try changing the plug wires and coil wire.
Old Mar 16, 2003 | 03:29 PM
bachehbad's Avatar
why does a car run rich though? and how can you stop it from running rich???
Old Mar 16, 2003 | 03:34 PM
my94blackz's Avatar
Well i burn so rich i throw flames
and i also have the notorius hesitation (0-2000)
Old Mar 16, 2003 | 03:50 PM
Rodrigues's Avatar
Well basically I had the 0-2000 RPM stumble, my car was completely stock and I was gettiing BLM's in the 111's, I was running way to rich then I got it programmed and it went away.
Old Mar 16, 2003 | 04:00 PM
bachehbad's Avatar
so think if i get my ECU reprogrammed it'll go away???
And did you guys have some powerloss too??? feels like i lost maybe 30 or 40 horsepower.
Old Mar 16, 2003 | 04:17 PM
cals400ex's Avatar
if you had NO problems before you installed the plugs, i bet that is your problem. maybe your wires or coil is bad. what i would do first is go back and make sure every plug is in tight and that you have a good connection with the plug wires. i also had the famous low rpm stumble and new o2's cured almost all of the problem. while checking the plugs/wires i would disconnect the battery to reset the computer and then connect it back up when your done. take it for a drive and let us know if it still missed.
Old Mar 16, 2003 | 06:59 PM
bachehbad's Avatar
Ok disconnected the battery for a good 10 minutes....
hooked it back up, still same stumbling....
but my car stumbles after 2000RPM, if im very easy on the gas it stumbles, if i accelerate relativly hard meaning 1/4 throttle, everything is smooth except slight loss in power.
Old Mar 16, 2003 | 07:07 PM
tkatchev69's Avatar
That sounds exactly like my problem. I hope someone knows our problem!!
