Injectors ?
Old Mar 12, 2003 | 11:33 AM
mysticslp2002's Avatar
Injectors ?
I need GM #38 injectors but tehy are way too expensive so i was going to use SVO #30 will these register as 36/38 in the LS1? Any suggestions were i can get injectors cheap? The 30s from SVO are orange red right? Thanks
Old Mar 12, 2003 | 12:18 PM
PhantomTA's Avatar
Moderator
yeah its about 36 at the ls1 Fuel pressure..
the 30's are red tops. the orange are 19's blue is 24
Old Mar 12, 2003 | 12:50 PM
stik6shift98's Avatar
what should fuel pressure gauge read.....mines at like 60psi...is that bad????
Old Mar 12, 2003 | 03:45 PM
2MCHPWR's Avatar
stick6shift,
60 psi is perfect.
here is a dyno graph of mine with bad fuel pressure at the top end.
hope that helps.
Old Mar 12, 2003 | 06:16 PM
35thanniv.SS's Avatar
Go on eBay. You can find some 30# injectors possibly under $200
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
