!Cruise Control?
Old Mar 10, 2003 | 08:47 PM
mtealz's Avatar
Question !Cruise Control?
Has anyone removed it. It sits on the drivers valve cover, I dont use it and it pisses me off. Can you just get a throttle cable from a non-CC car and remove the whole thing and disconnect the swith on the steering column without a light or other malfunction?
Wade
Old Mar 10, 2003 | 09:38 PM
I believe you are referring to ASR (traction control), not cruise control.
Old Mar 10, 2003 | 11:49 PM
mtealz's Avatar
Nope. It has to be a cable goes from inside the car to the box, then the cable that comes off of that goes to the throttle body.
Its not really a box, its the stepper motor for the cruise control with the black cover on it. Right on top of the drivers side valve cover. Doesnt traction control just bog the motor down anyway.
But has noone removed their cruise conrtol?
Old Mar 10, 2003 | 11:59 PM
The thing on top of the valve cover is the ASR. The cruise control is down on the inside of the LH frame. People that have cruise and no ASR have nothing on top of the valve cover.
Old Mar 11, 2003 | 12:13 AM
mtealz's Avatar
Sorry , I asumed it was, with the throttle cable attached to it. Do you know how i can remove it with out to much hassle. I dont need it anyway.
Thanks for the info
Wade
Old Mar 11, 2003 | 12:19 AM
If you wanted to get rid of all that stuff, IMO all you would have to do is remove it and get a throttle cable for a non ASR car. Not sure if the computer would complain about any of it.
Old Mar 11, 2003 | 12:26 AM
mtealz's Avatar
Thanks for the help. Ill probably try it. Im doing a A4 to M6 swap. Im also doing Hooker Lts and dont need ASR and I dont want to mess with the crap on the valve covers since I have to do OVC wires. Tahnks again I think you had the P/N for the throttle cable on your site right?
Thanks again
Wade
Old Mar 11, 2003 | 12:29 AM
mtealz's Avatar
Also just one last quick ? I promise
How does the cruise control work if its not directly connected to the throttle cable. (How does it work)
Thanks for putting up with my crap
Wade
Old Mar 11, 2003 | 12:32 AM
Buttercup's Avatar
Cruise control uses it's own throttle cable. I think the ASR box you are referring to is the throttle relaxer which just reduces tension on the main throttle cable. Since I don't have ASR can't say that I've looked all that closely at it though
Old Mar 11, 2003 | 12:38 AM
mtealz's Avatar
Thanks Buttercup I think I see how it works.
The ASR actually "boggs" the engine down by reducing the throttle. So does this mean a cable goes from the pedal to the CC to the ASR then to the TB?
Wade
Old Mar 11, 2003 | 12:42 AM
Buttercup's Avatar
No, one cable goes from the peddle, to the ASR, to the TB. The other cable goes directly from the cruise control box in the front fender to the TB.
You should have two cables attached to the throttlebody.
Old Mar 11, 2003 | 12:50 AM
mtealz's Avatar
I dont know havent pulled of that cheapo cover yet thanks Ill look at it later. I only saw the one going into the back top of cover. Ill look for the other. The chiltons manual sucks it doesnt have any info on this or much else for that matter.
Old Mar 11, 2003 | 08:05 AM
Thanks again
Wade
1994-1996 accelerator cable-no traction control 12550676 (on my site). The 1997 is 12554852 . Did not know what year your car was.
Old Mar 11, 2003 | 02:59 PM
mtealz's Avatar
Its a '95
Sitll confused. The cable labled WDS comes out of the pass compartment then goes to "motor" on the valve cover then two cables come off that . One labeled DJA to the Cruise control and the other labled WDR to the Throttle Body.
And buttercup I dont have two cables attached to the throttle body just one.
Old Mar 11, 2003 | 03:20 PM
The configuration without ASR has the cable coming through the firewall from the pedal to the TB and a cable coming from the cruise to the TB. You could get rid of the ASR and still use the cruise, I think, by getting both those cables.
