Mud???? In radiator....
Old Mar 10, 2003 | 08:06 PM
James3219's Avatar
My car was running a little warm today so I open the cap on the radiator and there was a muddy substance mixed in there. I am not sure what this is. The same stuff was there about 7-8 months ago and a freind and I flushed it out. What could this be and why is it in there again.
Old Mar 10, 2003 | 08:33 PM
JIMS1999CONVZ28's Avatar
Sent you a PM.
I am also thinking that the heater core could be a problem. I understand that a few guys have had a problem and if you have to pull it out, it is a PITA.
It could be your mix is not 50/50?
Jim
Old Mar 10, 2003 | 09:00 PM
mtealz's Avatar
I had the same thing in my overflow resivoir when I flushed my system a while back. Take out the battery and take out the overflow acnister and flush it out. www.bfanker.badz28.com/fbody/guides.htm
he has something on flushing it.
Old Mar 10, 2003 | 09:08 PM
1995redZ28's Avatar
i noticed the same thing when i flushed my system out last weekend. i would also like to know what this could be! almost looks like it is rust??!?!
Old Mar 10, 2003 | 09:16 PM
James3219's Avatar
Thanks for the info guys, but that link does not work.
Old Mar 11, 2003 | 01:07 AM
mtealz's Avatar
Sorry heres the right link
http://www.bfranker.badz28.com/fbody/coolant.htm
I had tons of crap in mine(the overflow container)
I just drained it filled it up with water, started it ran it for a min or two and drained it. Then filled it up again. No proplems since and its been runnig cooler.
Old Mar 11, 2003 | 01:58 AM
z28Power's Avatar
I would have to suggest just to make sure you do a thorough flush of the cooling system, fill up with pure water, run to temperature, turn off car, drain again, continue until fluids come out clear. Fill with 50/50 dexcool. This stuff gets grimy if it's dirty, try that out and see what happens guys.
Old Mar 11, 2003 | 02:58 AM
MysticTeal 95 V6's Avatar
Thats what I had to do a few months back... the temp gauge was sitting about 20 degree's higher than normal for a couple of weeks. Finally got around to doing a flush of the cooling system with distilled water... cycled it a couple of times to make sure everything was clean then filled it back up with a 50/50 mix of coolant and distilled water. The temps been sitting just below 180 every since.
Old Mar 12, 2003 | 04:02 PM
James3219's Avatar
Thanks for the info guys, I am off on saturday and I am gonna flush it then.
Jun 6, 2015 08:27 AM
Jun 5, 2015 10:16 AM
Mar 13, 2015 07:15 AM
Gripenfelter
Jan 27, 2004 12:02 PM
