Where is the heater inlet hose? (pic inside)
Old Mar 10, 2003 | 12:24 PM
z28sinx's Avatar
I have a backflushing kit I'll be using soon, I need to cut the heater inlet hose and 'splice' in a piece. The directions say use the hose running from the firewall to the top of engine, look here:
http://www.students.uwf.edu/lad2/enginebay3.jpg
There's three arrows, is what I want the green, red, or blue arrow (I'm thinking blue, the girth is throwing me off)? Thanks.
Old Mar 10, 2003 | 12:44 PM
americanmusscle's Avatar
If im not mistaken the green one is the top one but im not sure. there is also the second heater hose under the blue arrow hose which is the second one. The blue arrow hose i belive is a radiator hose not a heater hose. Might want to go with the green arrow hose but dont quote me on that.
Old Mar 10, 2003 | 01:07 PM
BUBBA's Avatar
If you look on the firewall, the one hose attached on fender side (with alum. pipe to rubber) should be the inlet hose. The hose on the right (all rubber) is the outlet hose.
So I guess if you follow the hose on the left you will see which of your hoses is indeed the inlet hose.
I replaced the outlet hose cause it got burned by my headers.
Someone please correct me if I gave the wrong info.
Old Mar 10, 2003 | 04:11 PM
The answer is none of the hoses you have arrows to. The green arrow is the heater outlet hose. The red goes to the remote reservoir and the blue to the throttle body.
See this diagram. So, Bubba, the hose with the more rubber at the firewall is the inlet hose.
Old Mar 10, 2003 | 04:18 PM
BUBBA's Avatar
Thanks. All this time I just assumed it was the outlet hose. Well, I guess I replaced the inlet hose then. And a bitch it was too.
dalynchmob
Feb 19, 2015 07:20 PM
Jlo
Feb 3, 2015 09:41 PM
crazypurgatory
Jan 12, 2015 10:45 PM
pologreen97z
Dec 2, 2014 10:42 AM
omarECD
Aug 19, 2002 07:28 AM
