MSM69Z28
03-09-2003, 04:58 PM
got a 383 with a crower .950 small base circle solid roller cam. this is in a late model block (87-95) with the taller lifter bores. i see comp cams sells lifters 883 and 893. 883 is .300" longer than standard lifter and 893 is supposed to work with small base circle cams.
http://www.compcams.com/catalog/263.html
since i have a combination of both, i need to know what lifter to order.
i measured the length needed from base circle to top of lifter bore which is 2.520". i am not sure if either of these lifters "vertical linking bar" will still hit the top of the lifter bore. anyone have any suggestions or information. i need to get this ordered asap. this is the only thing holding me up from wrapping up this beast.
thanks,
mike
Jason Short
03-09-2003, 06:01 PM
If you are using an LT1/LT4 block:
Comp cams Endure-X (CCA-888-16)
or
Crane 11522-16
Both are great lifters that have been used in LTx motors with great results
Jason
Turbo6
03-09-2003, 06:25 PM
Jason,
Concerning use of the Comp Endure-X vs. the Crane Solid roller lifter difference, do you know of any reason to go with the Endure-X over the crane's as there is about a $150 difference in price. Does one require the use of an oil restricter or do a better job of valvetrain stability or longevity than the other? Thanks.
MSM69Z28
03-09-2003, 06:52 PM
actually, not an LT1 block (i don't think), but still a late model block. the casting numbers is
14093638...350...87-95...2 or 4...Roller or flat tappet cam
one-piece rear seal
info found at:
http://www.mortec.com/castnum.htm
would this make a difference?
thanks,
mike
MSM69Z28
03-09-2003, 07:00 PM
also, any idea what the dimensions are from roller tip to bottom of link bar (vertical link bar not spring loaded lifters). i have 2.520" from cam base circle to top of lifter bore. can anyone confirm the .300" taller lifters dimensions?
thanks,
mike
You can also machine down the lifter bore and use a standard size lifter.:cool:
MSM69Z28
03-09-2003, 07:56 PM
ouch. just got 2k worth of machine work done and engine is in car. not coming back out :-)
i'd duck tape two lifters together before that. :-)
mike
JordonMusser
03-09-2003, 09:16 PM
the 11522s should work. I would stay away from the endurax. Ihave seen SEVERAL come appart.
I have run 11522s with a <.900 base circle cam in an LTX block NP
SStrokerAce
03-10-2003, 12:19 AM
The 883 will clear.
You will also need shorter pushrods most likely, but that's not a bad thing.
Having a pushrod checker is always a good idea.
Bret
Jason Short
03-10-2003, 09:00 AM
As Jordon said, the 11522s are good...I use them in my motor as well. I have never personally seen anyone have problems with the EndureX lifters, but Jordon has so I am not sure what the story is on them. All of the applications that I have seen them used in have worked well.
The EndureX have an extra oiling groove in them, whereas the 11522s do not. Are they worth the $150 extra? Mabye....but I went with the 11522s and have not regreted it one bit.
Jason
MSM69Z28
03-10-2003, 10:42 AM
thanks fellas. you've been a great help.
mike
MSM69Z28
03-10-2003, 11:50 AM
one more thing. i see crane makes a 11552 which is the horizontal linking.
which do you guys think is better. vertical linking (with the spring for easy cam changes) or the horizontal linking.
11522 is around 280.00
11552 is around 380.00
the price difference worth anything. different quality or durability?
any help appreaciated.
thanks,
mike
MSM69Z28
03-10-2003, 11:52 AM
****, one more question. sorry.. lol
can the taller lifters be installed with the heads already on. i hope so because mine are on already. :-(
mike
