SABLT194
03-09-2003, 07:35 AM
I just finished reassembly of my LT1 with redone heads. I checked the push rod length with the Comp Cams cheepo plastic thingy and it showed that my pushrods were about .030" short. I went ahead and finished the assembly with zero lash plus 1/4 turn and fired the motor to look at the contact pattern on the valve tip and sure enough the patern was slightly "centered" toward the header side of the head. I then re adjusted the valves down to zero lash + 3/4 turn and the pattern moved back closer to the center of the valve tip.
What's a reasonable allowable error in pushrod length. My gut feel was that .030" wasn't going to be a problem.
Steve
Steve
