Pacific Alaska, California, Hawaii, Oregon and Washington
Cam still for sale
Old Mar 7, 2003 | 09:43 PM
NiteRider's Avatar
Exclamation Cam still for sale
Link to for sale:
Didn't want to wait anymore so it's up for grabs to anyone.CAM
Old Mar 12, 2003 | 09:15 PM
BennyBoy's Avatar
If I were to pick up this cam, what would I also need to purchase? Ie... springs, lifters? I have a 95... I believe there is some difference in some dowel pin or something like that. Is this a concern?
Edit: Would this cam be OK for a stock stalled car with 2.73s?
Old Mar 12, 2003 | 09:34 PM
Draco's Avatar
You should buy new valvesprings/retainers at least. You might also want 1.6 roller rockers if you want to rev past 6k and if you want a little more power. If you buy the roller rockers, you might also want to buy larger roller rocker studs and guideplates if you go with non-self-aligning roller rockers.
You would not necessarily need new lifters unless you have high miles or have reason to believe that your lifters are in bad shape. However if you want to rev over 6300 some R lifters would be a good idea.
I am pretty sure Armen bought a cam designed for a 95+ car, so you should already have the proper water pump/opti setup (you don't need to do the full opti conversion).
I would think cam this small would be just fine on a stock stalled auto.
Old Mar 12, 2003 | 10:12 PM
NiteRider's Avatar
Heh, thanx Craig, yeah a machine shop can take care of the dowel pin.
Old Mar 13, 2003 | 04:26 AM
bunker's Avatar
Yes generally you want the shank portion of the rocker stud to be just under or the same level as the rocker fulcrum.
Old Mar 13, 2003 | 11:22 AM
Draco's Avatar
We're not so different, you and I.
Old Mar 13, 2003 | 01:44 PM
SBainsTA's Avatar
OOHHH That's a scary thought!!
EVERYONE,
BE AFRAID, BE VERY AFRAID
Old Mar 13, 2003 | 05:34 PM
NiteRider's Avatar
Once again my for sale thread has been mutilated by some of you common rifraft. Especially Craig, you should know better then to quote austin powers 3 on this board.
LeftoverChinese
Jan 14, 2024 03:03 PM
oldschool
Feb 9, 2016 09:21 PM
pimpss96
Feb 12, 2015 01:28 PM
Queens94z28
Dec 20, 2014 09:11 PM
