T56 conversion question
Old Mar 6, 2003 | 05:05 PM
JDMZ28's Avatar
Getting those pedals in there was a P.I.T.A.
The kit I bought did not come with the nuts I need for the U-bolt, will ordinary nuts be just fine?
Where is the location of the wires I need to cross for the clutch switch "bypass"? How hard is it to wire this switch into the auto wiring harness?
Old Mar 6, 2003 | 05:44 PM
AlexA's Avatar
Told you it was a PITA.
Yes, you can use normal bolts, though I would get the U-bolt.
The wires are in the Park/Neutral wire pack on the right side of the A4 shifter.
-Alex
Old Mar 7, 2003 | 04:10 PM
JDMZ28's Avatar
Hey alex thanx. In my post above it says I have the u bolt but I need the nuts for it. I can assume anyones will do fine. Yeah it took me an hour just to get them mounted in there, its hard to line it up with all those studs coming off the firewall and those stupid wires hanging down.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
cmdeshon
Dec 27, 2014 10:06 AM
Queens94z28
Dec 20, 2014 09:11 PM
