Tranny clunks very often
SpecForceZ28
03-05-2003, 08:08 PM
Hey guys, I know that its normal for our transmissions to clunk at low speeds(Note I have an A4). Well recently, (Gear is in OD) my transmission clunks when i am going at least 35 mph. At speeds above that I don't notice the clunking or hear it. Any ideas as why this is occuring? Thanks for the help.
jd13
03-05-2003, 09:00 PM
I know the M6s clunk. I haven't heard much about A4s making much noise. But then again I don't know much about that type of tranny.
Any clunking when you get on it? If so, it may be your tranny mount.
SpecForceZ28
03-05-2003, 09:07 PM
Theres no clunking when its WOT. It's only if I apply around 10-40% throttle.
EDIT: When Im traveling at very low speeds, it will always clunk, and sometimes it makes a high-pitched clunk.
dmnall
03-06-2003, 03:15 AM
Well jack the car up and put it on Jack Stands or better yet put it on a Lift and check the Tranny Mount and then Check the Ujoints... and if there is nothing wrong with either then take the car to the dealer and have them check it... That reminds me I have to call local dealer and have them replace my rear transmission seal as well on my car...
Pewter99_Trans
03-06-2003, 05:45 PM
My car does the same thing man. It never does it when Im WOT. It will do it when i kind of ease out of 1st and when Im a crusing like you were talk bout at like 30 something it will clunk.
stik6shift98
03-09-2003, 11:09 PM
how are you guys sure its not the trans mount....i thought it wasnt mine either because by looking at it it looked great but i decided to change it anyways and the problem was solved....mine must have been ripped the slightest bit 4 ever and one day it got a little worse but still not to the point that it would be visible
chevy qc
03-09-2003, 11:15 PM
does the clunking noise happen at steady speeds, off idle accel., when shifting??? very likely a trans mount can do that although they tend to make plenty of noise at wot when bad also which sometimes can't be heard though due to engine noise/exhaust. quite often on the 4l60e you can hear the 3/4 clutch set apply when the shift to third happens which is for the most part normal.
stik6shift98
03-10-2003, 12:17 AM
even at wot the trans would have to make noise if the mount was open because u could gradualy get up to that speed and then id would be fine......
a poly trans mount can be bought for 25 bucks...why not just get it anyway
and i think my buddy will sell his black ploy mount for 15 if anyone is interested
chevy qc
03-10-2003, 12:26 AM
i agree with you on replacing the trans mount, the stock one isn't that good anyway and will eventually break anyway. if it's not under warrenty still, i'd replace it anyway.
stik6shift98
03-10-2003, 12:48 AM
oh.........maybe yours is fu@!ed up.....ill sleep on it and give you some advice:p :D :D
SpecForceZ28
03-10-2003, 01:09 AM
I'm hoping a tranny fluid change will solve my problem, this clunking sound is really annoying.
stik6shift98
03-10-2003, 01:28 AM
i dont wanna be the bearer of bad news but i dont think the trans oil change will do it:(
