Wilson
03-03-2003, 04:37 AM
Im looking at the HiFonics Zeus Z6400 (85x4 RMS). I need a 4ch amp to run my speakers. This amp is kind of cheap ($219). Anyone know if this is any good?
The Z6400 is part of the redesigned Zeus Series from HiFonics and is designed to deliver competition-grade performance with HiFonic’s renowned reliability and sound quality. The Z6400 features HiFonics’ “Generation” sleek heat sink design and utilizes a PWM power supply, a 12 dB / octave high pass crossover variable over 10-1,200 Hz, a super-steep 24 dB / octave low pass crossover variable over 50-150 Hz, bass boost variable over 0-18 dB at 40 Hz, and molded 4-gauge power connections and speaker terminals. The Z6400 doubles its rated power when bridged (unlike many inferior amplifiers) making it a real powerhouse.
Features
PWM Power Supply
High Speed MOSFET Outputs
Regulated Power Supply
12 / 24 dB octave Variable Crossovers
Class AB Operation
Subsonic Filter
Multi-Channel Amp Specifications
Amplifier Type: Multi-Channel
RMS Power: 85W x 4
Bridged RMS Power: 340W x 2
THD at Rated RMS Power: < 0.03%
Speaker Level Inputs: No
Preamp Outputs: Yes
Built-In Crossovers: HP/LP
Bass Boost: 0-18 dB
Frequency Response: 10-30,000 Hz
Channel Separation: > 70 dB
Signal to Noise Ratio: > 95 dB
Fuse Rating: 70 amps
Shipping Weight: 14.5 lbs
Warranty: 1 year
Features
PWM Power Supply
Class AB Operation
Subsonic Filter
RMS Power: 85W x 4
Preamp Outputs: Yes
Bass Boost: 0-18 dB
Warranty: 1 year
