Ordered wrong plug wires - Can we make them work
Old Mar 1, 2003 | 11:18 PM
ryker77's Avatar
Ok I bought a set of Accel 9000 extreme plug wire part number 9003 off of ebay. (Price was good) PN 9003 have bendable plug boots. He sent me PN 9000 which are straight and non bendable
The 9000 extreme are designed to handle higher heat and I'll be using them with Hooker Shorties Jet-Hott Coated headers. Also have over the valve cover loom kit.
Can I still use them even though they are straight plug. They do flex some.
Does one have to use distributor ends designed for only a LT1? I've read otherwise. I can order the LT1 taylor ends for 12.00
Old Mar 1, 2003 | 11:26 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: Ordered wrong plug wires - Can we make them work
thunder racing has the LT1 ends
that might help
Old Mar 1, 2003 | 11:30 PM
ryker77's Avatar
Luckly I found them. They are the only place to sell the opti ends You'd think jegs or summit would.
Any ideal if the spark plug ends will work? I sorta think or at least hope they will. But I don't want to try and waste my time.
Old Mar 2, 2003 | 01:08 AM
ryker77's Avatar
ttt
Just need to know If the straight plug ends will work?
Old Mar 2, 2003 | 05:35 PM
ryker77's Avatar
TTT
Can I use straight end plug wires OTVC with Hooker Jethott headers?
thanks
Old Mar 2, 2003 | 08:24 PM
ryker77's Avatar
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
sleeperZ96BT
Jun 5, 2005 09:33 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
