motor mount question
Old Mar 1, 2003 | 09:18 PM
rumair's Avatar
i'm going to be building a 6" rod, 4-bolt block 383 in the near future. i want to upgrade the motor mounts and was wondering if i should go with solid or poly? i've seen the poly mounts on thunder racing's site, but i have no idea which one would be right for my application.
TIA for advice and/or suggestions.
Old Mar 2, 2003 | 04:32 PM
rumair's Avatar
so everybody who has a stroker is using the stock motor mounts?
Old Mar 2, 2003 | 05:13 PM
blownbird01's Avatar
If this is a street driven car, do not do solid mounts. Wat too much vibrations. Even the poly mounts will shake the **** out of you. If you can, I would stick to stock rubber. Unless you don't mind feeling every shake and bump your car has to offer.
Old Mar 2, 2003 | 05:54 PM
rumair's Avatar
the car is strictly a saturday night driver. one of the reasons i asked about new mounts is that i think i may have left one of the brackets attached to my old block that the machine shop threw away. i'm assuming that the general will want more for stock replacements than the poly or solid mounts cost. maybe i'll have to look around in the attic for all the brackets...
HectorM52
Jul 30, 2017 11:46 AM
alliance12364
Mar 6, 2015 04:39 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jazsun
Dec 29, 2014 12:14 PM
