What size injectors should I get?
Old Feb 28, 2003 | 04:45 PM
vendela99's Avatar
I have a 98 with the 28# injectors, but I assume I need to go bigger. I am making about 375 rwhp right now and will be spraying a dry 125 shot. I am adding a Walbro 340 fuel pump, and I'm wondering how big should I go on the injectors? There is a possibility I would add long tubes down the road also.
Old Feb 28, 2003 | 07:26 PM
stik6shift93's Avatar
The 28lbers can support a bit of power, though you'll need to upgrade anyway since your running a dry kit. I'd go with some 36lb injectors, they're big enough to give you leeway if you want to up the shot.
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
QuickSilver02
Apr 7, 2015 11:12 AM
drptop70ss
Mar 26, 2015 01:50 AM
