Good suspension...help me!
Old Feb 26, 2003 | 10:19 PM
stik6shift00's Avatar
I have SLP level one suspension and it blows, i have $hit loads of wheel hop, i need something new and i dont really want to spend any more than 400 for front and back shocks and springs.
Also can you tell me how much a panhard would help out, and how much a BMR torque arm would help out my traction problems.
Old Feb 27, 2003 | 12:20 PM
ttt....help help help!!!
Old Feb 27, 2003 | 12:56 PM
any one????
Old Feb 27, 2003 | 02:09 PM
stik6shift93's Avatar
Try some bmr boxed lcas and a bmr torque arm, it'll help out a bit.
Old Feb 27, 2003 | 11:09 PM
AL SS590 M6's Avatar
Moderator
If wheel hop is your main concern.
Put on some good LCAs with relocating brackets and your problem will go away.
Old Feb 28, 2003 | 08:23 AM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
Thumbs up
BMR is the way to go:
http://www.bmrfabrication.com/F4.htm
Very well constructed, and great customer service, I have purchased all of my suspension products from them. Brett's the man!!!
SteveC
Old Feb 28, 2003 | 09:09 AM
poniekiller's Avatar
lca relocation brackets
lightweight lca's
shorter torque arm (adjustable)
stickier, bigger tires
remove front sway bar
let your rear springs age, leave 'em there.
adjustable shocks ($40-400 each, you choose)
IMO, panhard bar is not a big deal, you can check to see if you need one by measuring the distance between the inside of your rear rims to the inside of your wheel well. If one side is more than 1/2 inch off, you can use the adjustable panhard to center your rear-end.
Old Feb 28, 2003 | 10:09 AM
Yeah I almost forgot, get a pair of competition engineering adjustable drag shocks....They're only 80 a pair and work great.
Old Feb 28, 2003 | 12:52 PM
Ok..so those comp. shocks, lower control arms...and a torque arm? is that good
Old Feb 28, 2003 | 12:56 PM
I agree, I'd rather buy comp engineering shocks every year than a set of HAL's. Same compression numbers, period. I'm sure some will argue.
Old Feb 28, 2003 | 12:57 PM
get the lca brackets while you're down there, they aren't expensive.
Old Feb 28, 2003 | 03:01 PM
My84Z's Avatar
since your gonna be driving this on the street do not remove the front sway bar no need to take a corner and kill yourself just get some nice lca's and some good springs for now personally i would get dms springs and later a tourque arm and some nice shocks.
Old Feb 28, 2003 | 07:13 PM
Joe I just got off the phone with a guy who's parting out his z and has full suspension, contact me for details.
Old Feb 28, 2003 | 10:16 PM
casebuzz's Avatar
Get the LCA relo brackets and see if things improve. The SLP Level 1 is a great kit for the street, but they should've included the relo brackets - even the small 1" drop totally screws up the LCA geometry.
Old Feb 28, 2003 | 10:26 PM
stik6shift98's Avatar
hey joe to correct stik93 its a 2000 ss and it has way to many parts to list.....even a 12 bolt 409 stroked moter etc......
call me
later
