Oily stuff in intake.
Old Feb 26, 2003 | 05:37 PM
scott95ta's Avatar
I am in the process of repairing the intake oil leak, yes still . I noticed that the is an oily film on the inside of the intake. I am assuming that this is from when the valve cover tube was connected to the TB and oil was sucked into it. I have since removed this tube and added an air breather to the valve cover.
My question, finally, is should I clean out the intake with some carb cleaner or just not worry about it?
Thanks.
Old Feb 26, 2003 | 05:45 PM
DjArcadian's Avatar
It's normal. You can use carb cleaner to clean it up. Doesn't really harm the engine so just do it after the intake is reconnected.
Old Feb 26, 2003 | 06:22 PM
FreByrd2's Avatar
i just did my intake oil leak fix also, and my intake was oily. I used some carb cleaner and a wire brush, looks like a toothbrush. From what i understand its normal. A good cleaning wont hurt any.
jason
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
football4life
Oct 4, 2015 07:48 AM
cmsmith
Sep 14, 2015 09:09 PM
tommalcolm
Sep 11, 2015 03:39 PM
jackpawt883
Sep 10, 2015 08:53 PM
