what parts will i need for my Jet hot longtube header install...
what is the part number for the Stage 8 locking bolts
what felpro gasket partnumber....
do i need o2 extenders and which ones(part number too)
i have a 95 Transam with single cat....
thanks,shawn
thanks,shawn
Since I found this only post on search looking for the part number of Stage 8 Locking Fasteners I give what I have
#8911
SB CHEVY
Locking Header Bolt Kit
bolt is 3/4" in length
allen head bolt
fits into
7/16 or 11mm socket size
don't know allen size
someone else can chime in
#8911
SB CHEVY
allen head bolt
fits into
Give LS1 Speed a call. They have all the necessary parts and can help you in choosing what you'll need for your application. Also,their website has all the parts listed in case you wanted just the part numbers. I ordered all of my header accesories from them and had them delivered in around 3 days.
Fel-Pro 1406 Header gaskets
O2 Exstensions:
99-O2EXT Oxygen Sensor Extension, 24" Flat 4-Pin (Front Sensor on 1994-1997 F-body, Front & Rear on 1994-1996 Impala SS)
$25.00
Thunderracing.com
O2 Exstensions:
$25.00
Thunderracing.com
If your hooking up your AIR on each side/front of headers it takes (2) 3/8" to 1/2" male to male standard thread fittings. The EGR on the driver side underneath bolts in direct no fittings needed. Also on the 02 extensions, my understanding is that most don't want to pull the wire out of the factory looms to stretch & reach the 02 bungs at the collectors. I'm planning to just cut/splice & add wire for mine.
This is per Todd at JetHot, good luck let me know how it goes? Mine will be here next Tues
. I'm doing a custom ypipe with (2) 3" FlowTech cutouts right after the collectors and nocats
with the existing 3" Borla.
OTVC kit from Thunder Racing
Taylor Heat Sleeves to be safe
8 NGK TR55 spark plugs
1 inch long Stage 8 header bolts part # 8911-A
Felpro 1406 header gaskets
2 - 2 foot o2 extension or make your own
Roll of Heat tape
1 - 12x12 sheet of adhesive backed heat shielding for the heater box, and starter.
mufflex y-pipe or custom made y-pipe from your local muffler shop
pair of new 02 sensors
Zip ties, oil filter, oil, dielectric grease, anti-seize compound, roll of convoluted tubing, crimp connections, and nuts/bolts of various types to connect the EGR.
Hope that helps.
-B
Roll of Heat tape
Hope that helps.
-B
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
