basic routing question
GoFast908Z
02-25-2003, 10:40 AM
how do i find the hole in the firewall to sneak the power wire for my amp into the engine compartment and to the battery?
LS1 RULZ
02-25-2003, 10:50 AM
Under the hood on the passenger side you'll see the PCM. Its far back towards the windshield next to the hood's hinge. You'll see a lot of wires going into a couple of harnesses that plug into it. Theres 2 10mm bolts that hold it in. Remove the 2 7mm bolts holding the harnesses in and set the harnesses aside. Then remove the 2 10mm bolts holding the PCM secure. Now you can turn the PCM sideways so that the part where the wires went is now facing the passenger fender. The PCM will now lift right out with ease. You could leave the harnesses attached but it causes you to have to struggle to get the PCM out of its cubby hole. You'll now see a rubber grommet in the firewall. You can fish your wire thru here. Now inside the car, go to the passenger side kickpanel, up behind the glovebox you'll find your wire. Its usually easier to remove the kick panel to find the wire.
stik6shift98
02-26-2003, 12:53 AM
thats where the gf with skiny hands comes thru and feeds the wire thru....didnt even have to loosen the pcm:D
GoFast908Z
02-26-2003, 03:19 AM
Hey LS1RULZ, what that sequential turn signal thing in your sig?
LS1 RULZ
02-26-2003, 06:54 AM
It blinks the tail lights in sequence pointing in the direction of the turn. It works just like the tail lights on the old Cougars used to do. I got the kit from Blink Blink (http://www.blinkblink.com).
stik6shift98
02-26-2003, 10:12 AM
thats sweet did u do instlll your self?
how hard was it?
how much did u pay?
LS1 RULZ
02-26-2003, 10:25 AM
Did it myself. Only took about an hour. I forget how much it was. It's been a couple of years ago now.
stik6shift98
02-26-2003, 10:28 AM
do u like them?
i think its sweet
can u get a video of it?
LS1 RULZ
02-26-2003, 10:34 AM
I love em. I get people asking me about them all the time. I don't have a video but they have an animated demo on the web site.
stik6shift98
02-28-2003, 12:04 AM
my buddy wants to know if they have them for a transam.....
LS1 RULZ
02-28-2003, 06:17 AM
Sho nuff. My car is a '99 T/A (http://www.sounddomain.com/id/whiterascal).
