exhaust tick
Old Feb 24, 2003 | 03:48 PM
Cream's Avatar
exhaust tick
Had my MAC headers installed this weekend. As soon as I took it out I noticed a loud ticking on acceleration. Both my installer and I attributed the noise to exhaust hitting the primarys/ internal noise amplified by the thin tubing of the primaries. Those with MACs (or others) can you relieve my mind and attest to this?
Michael
Old Feb 24, 2003 | 03:56 PM
95TA8280's Avatar
I hope you don't have an exhaust leak.........
Old Feb 24, 2003 | 04:05 PM
EviLBoX's Avatar
What your installer said is possible, but I'd check for leaks at the header/y-pipe connection and the header/head connection. I also have a tick that I've never been able to find, I know it's not an exhaust leak.
Old Feb 24, 2003 | 04:13 PM
americanmusscle's Avatar
fuel injectors??
Old Feb 24, 2003 | 04:15 PM
Cream's Avatar
Thanks guys,
I will be checking things this weekend a tightening the bolts after a few heat cycles.
It just seems I remember reading about the thin primary's allowing you to hear the exhaust stiking them, along with allowing internal engine noises to be heard.
Michael
Old Feb 25, 2003 | 10:46 AM
Cream's Avatar
Course it still bothers me.
The more I listen to it, the more I think it can't be normal. The tick is as loud on the inside as the exhaust note. While digging my car out this morning from the snow, the interior reeked of exhaust fumes. Looks like I got more work to do.
Michael
Old Feb 25, 2003 | 11:05 AM
If everythng was relatively clean, you should be able to see where there is an exhaust leak (if leaking where there is clear view). There will probably be some soot where the exhaust is escaping.
Snow?
Old Feb 25, 2003 | 06:56 PM
GEES97TA's Avatar
Unhappy
Oh great thats not what i want to hear exhaust ticking sounds im having MAC'S installed too, i really hope in you case its just a leak you can fix, i swear if i have the ticking noise i will SCREAM REAL LOUD please keep us posted what header gaskets did you use and did you check were the header bolts together by the stearing arm just some ideas....
Old Feb 25, 2003 | 07:34 PM
siberiankiss's Avatar
after having my headers installed, i also have noticed a loud ticking noise...mine is an exhaust leak from the area where the y-pipe collecter meets with the cat...the clamp on it is pretty shotty, so the only way i could get rid of it would be to weld it together, but then i have to cut everything off, so ive learned to live with it...i dont even notice anymore...
Old Feb 26, 2003 | 03:29 PM
Cream's Avatar
Rob,
Yeah, snow yesterday and ice today. Luckly, I work for the State and it's easy to call in. Haven't been anywhere in two days.
Gees97TA,
I used the OEM metal gaskets. Had heard good things about them. You no longer have to worry about the slip tube around the steering arm. It's welded together from the factory. That is if your using the dual cat headers. Otherwise, I don't know.
Siberiankiss,
I hope I don't have to weld either. Don't know if you could get into the narrow spaces to weld anyway. Problem is, I've welded the y-pipe to the I-pipe and there's not much slack. I've got to make it work regardless. With the cat so close to the the collector on the drivers side, it was difficult to torque things down. We ended up taking the heat shield off for more room.
Michael
Old Feb 26, 2003 | 04:21 PM
BUBBA's Avatar
When I first had SLP shorties installed, I noticed a louder than usual ticking noise (besides the RRs). Checked header bolts and sure enough the 0ne of the damn ARPs was 1/4" out.
Best to check them at each oil change and when you get the urge. Not a pleasant chore, but better than blowing out a gasket. JMHO
Old Feb 26, 2003 | 05:13 PM
GEES97TA's Avatar
I went with the single cat set up to element the dual cat's, i am also using the OR pipe so i dont know if that will make a difference in exhaust leaks. I sure hope so i dont want to hear that annoying ticking sound. I had edelbrock headers on my 89 iroc 350 tpi and they seemed to make alot of ticking noise's i dont know if that was because of the header brand,maybe cheap gasket or that is the trait of headers just to have that noise. please keep us informed on how you make out ok. My car is in the shop right now geting some upgrades for this spring and one of the upgrades is the MAC headers...
Old Mar 13, 2003 | 01:03 PM
Jim_H's Avatar
Just out of curiosity, how hard is it to change header gaskets after installing headers?
I think I blew out the passenger side. Shouldn't have reused the old stock gaskets
Old Mar 13, 2003 | 01:32 PM
A41995z28's Avatar
It's not hard to change the header gaskets, its just time cunsuming. If you are the type of person to easily get mad I suggest have someone else do it. If you don't mind the time it takes and can follow directions well, then you should be fine. I highly suggest you use Haynes Repair book. You cannot go wrong.
Old Mar 13, 2003 | 03:15 PM
Fast Caddie's Avatar
If it's MACs you have, then it is most likely the slip tube. Mine leaks/ticks and has for a while, but I'll finally get a chance to fix it this weekend.
Did your installer use a U-clamp or the crappy sleeve clamp that came with the headers? Get a U-clamp and tighten it down GOOD with header sealant smeared inside the joint. I used a U-clamp on mine, but the sealant blew out and I have a tick. HTH
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
May 21, 2015 01:04 PM
May 15, 2015 10:43 AM
94Z28LS1toLT1
Apr 30, 2015 05:19 PM
importkiller94
Jan 17, 2015 09:03 PM
