Coolant puddle under car after very cold night
Old Feb 24, 2003 | 03:31 PM
Camaro37's Avatar
Exclamation Coolant puddle under car after very cold night
Last night it got really cold (for here anyway), just under 0* F. I had prolly 35% coolant/antifreeze and 65% water in the system, and I checked the radiator before starting the car and there was a little slush just on the cap. So I warmed it up and as I was leaving I noticed a good sized coolant puddle under the car. Did I pop a freeze plug or what? I didn't have any leaks before. Wouldn't coolant be pouring out if I popped a plug?
Old Feb 24, 2003 | 03:44 PM
Geoff Chadwick's Avatar
if you popped a freeze plug it may not gush out. My best thought is see where the puddle is under the car, then look on the underside for drips. Could be waterpump, could be a bad hose clamp, could be a freeze plug. Either way, make sure you dont run out of coolant.
calaban
May 18, 2020 06:43 PM
Britbilly
Jan 7, 2015 08:49 PM
jj71787
Dec 30, 2014 02:15 PM
jayblev95
Dec 1, 2014 06:55 AM
USAirman93
Nov 24, 2014 03:37 PM
