How hard is it to fix...
Old Feb 24, 2003 | 01:03 PM
GrdLockV6's Avatar
...when I hit the curb a few weeks ago the front end got a lil messed up. The alignment is still pretty much fine I think (hard to tell cause it's been windy and the rear-axle was still bent), but the steering wheel is out of position, ie: when the car goes straight, the wheel is turned to the right a bit... it's not the alignment though as it still drives straight. How hard is it to fix that, or should I just take it somewhere?
Old Feb 24, 2003 | 01:26 PM
stik6shift93's Avatar
If your steering wheel is off like that then you have bent suspension components, I'd defiently take it in and have it checked out.
Old Feb 24, 2003 | 01:42 PM
GrdLockV6's Avatar
Bleh I just spent $3500 on new rims and a 12 bolt! Don't tell me that
I've had it happen before... when I wrecked my V6 once, the body shop repaired it and when I got it back the steering wheel was WAAAY off, like almost sideways. I took it back and in a few hours they had it fixed. Can't be that big of a deal... just the gears on the steering column are off or something?
Old Feb 24, 2003 | 01:46 PM
My84Z's Avatar
if it was just your steering wheels yes any alignment shop can fix it but if you hit the curb that hard i would say you bent a tie rod end or some linkage up there. just go to any alignment shop and get the front aligned with the steering wheel and they will fix it.
93 RedBird
Nov 15, 2015 08:24 AM
Bxlt1
Sep 29, 2015 03:18 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
