Someone please tell me what this hose is for!
Old Feb 23, 2003 | 06:56 PM
cocheese's Avatar
Question Someone please tell me what this hose is for!
Ok, I have a 94 z with stock air intake (except for K&N and 1LE elbow) and I want to know what the hose running to the plastic piece of the intake (to the right of the MAF housing) is for. I recently did the TB bypass and when I hooked everything back up, the car's idle was really rough and choppy. When I took this hose off, It was fine. While it was running, I put my hand up to this hose and there was suction. What Is This Hose for, and why does my car idle terribly when it's hooked up? Thanks in advance guys, !
Old Feb 23, 2003 | 06:58 PM
RamAir95TA's Avatar
If the tube is kind of large, it's for your AIR pump. If it's small with a blue elbow, that's the vacuum line for your optispark.
Old Feb 23, 2003 | 07:04 PM
cocheese's Avatar
It's kinda big. It connects on the backside of the intake piece. and where is the vacuum line for the Optispark you mentioned? Thanks.
Old Feb 23, 2003 | 07:07 PM
Max 93's Avatar
94's don't have a vented opti
Old Feb 23, 2003 | 08:16 PM
TMDZ28's Avatar
i would like to know the same thing
Old Feb 23, 2003 | 08:36 PM
97droptopZ's Avatar
I am pretty sure it is an AIR hose. It said so in my k&n CAI install instructions. Just some crap w/ emissions so they can stop our cars from getting the optimal hp they need
Old Feb 23, 2003 | 08:37 PM
ltlhomer's Avatar
Definitly your AIR hose.
Old Feb 23, 2003 | 09:29 PM
cocheese's Avatar
would it run better if i left it off?
Old Feb 23, 2003 | 09:38 PM
CamaroBoy96Z28's Avatar
Leave it on if the AIR system is fine. There isnt power to be gained or lost.
Old Feb 23, 2003 | 11:31 PM
Anderson's Avatar
I agree with leavign it on, but his post said that his car had a rough idle until he took the hose off, then it was fine.
That seems kinda strange.
Old Feb 23, 2003 | 11:45 PM
cocheese's Avatar
Ok, I just took it down the road a little bit ago, and this is what was concurred. When I first started it, I pulled the hose off and I could feel suction. I then put it on and it started to idle badly, like it wasn't getting enough air. I left it on and took it down the road and let it warm up. I got out and again took the hose off. This time, no suction. So my boy and I concur on the idea that it only does this while it's cold. Reason being??? But thanks for all of the replies. You guy's know your stuff and such!
Old Feb 24, 2003 | 12:14 AM
If you pulled it off and felt suction on the hose side (not the intake tubing side), it is because the AIR pump is running when the engine is first started cold and that hose is the filtered air supply for the pump. It is drawing air from the intake tract and that is why the suction was there (and not there after engine warm up).
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
