power antenna problem
Old Feb 22, 2003 | 02:25 PM
whiTetAlt1's Avatar
my antenna just stays up when the car or radio are turned off. I tried to manually push it down with not too much force, but it wouldnt go down, i stopped cause i didnt wanna break it. is there any way i can fix it for free, at least get it to go down, I never listen to radio anyways. help is appreciated
Old Feb 22, 2003 | 04:05 PM
moparman's Avatar
If you can't push it down, the only thing left is to replace it. AFAIK, there are no repair kits/parts available.
Old Feb 22, 2003 | 04:41 PM
drop top steve's Avatar
First check to see if your getting voltage to the antenna motor, if not, you could just use a jumper wire and retract it. If the motor is bad you can remove it, lower the antenna, with the motor removed, then reinstall. If the motor works then the plastic tape inside the housing is broken, you can get a new one from GM.
Old Feb 22, 2003 | 06:48 PM
moparman's Avatar
I tried to get a new tape/cable for mine. Dealer said not available.
siguy
Nov 27, 2014 10:07 AM
97_396_WS6
Aug 4, 2002 10:23 PM
Red97LT1
Aug 4, 2002 08:01 PM
Red97LT1
Aug 3, 2002 07:29 PM
$hawn
Aug 3, 2002 04:59 AM
