What should I do about a TB gasket?
Old Feb 21, 2003 | 06:25 PM
96z's Avatar
96z
I need a 58mm gasket for when I put my TB back on. Where can I get one. Should I just enlarge a 48mm one?
Old Feb 21, 2003 | 06:27 PM
RamAir95TA's Avatar
Yes, just make a stock one larger.
Old Feb 21, 2003 | 09:34 PM
96z's Avatar
96z
Any suggestion as to where I should get one?
Old Feb 21, 2003 | 09:47 PM
97TA-WS6-Con's Avatar
I'm having the same problem. Edelbrock does not make them any more or something like that.
Old Feb 22, 2003 | 12:22 AM
Prince's Avatar
Matt,
If you're looking for a stock one, I'm 99% sure I have one. I got it last spring when I did the intake oil leak fix, and never needed it cause I took the intake and TB off as one. I don't see any reason for needing one in the near future, so you can have it if you want.
Dave
Old Feb 24, 2003 | 12:35 AM
96z's Avatar
96z
You have mail Dave...
Old Feb 24, 2003 | 12:53 AM
96ltz's Avatar
http://www.lingenfelter.com/lingenfe...=16&pf%5Fid=44
Is that what you need?
Old Feb 24, 2003 | 01:37 AM
Dr.Mudge's Avatar
I just use light RTV.
Old Feb 24, 2003 | 07:07 AM
Brent94Z's Avatar
Super Moderator
AS&M and Holley still sell 58mm gaskets.
Old Feb 24, 2003 | 08:30 AM
Compstall's Avatar
...OR, if you've got a steady hand and an X-acto knife, you can make one out of cereal box. Done it many times with many things....
- Brent
Old Feb 24, 2003 | 08:45 AM
red's Avatar
red
I just used the a stock gasket and opened up the holes with a razor blade.
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
pepon214tx
Sep 20, 2015 04:48 PM
