BAD 97 WS-6
02-21-2003, 12:05 PM
My alarm has gone bad, and I need to disable the Starter kill feature on the alarm. What has to be done?
Help, I need to disable starter killBAD 97 WS-6 02-21-2003, 12:05 PM My alarm has gone bad, and I need to disable the Starter kill feature on the alarm. What has to be done? eyeoutthere 02-21-2003, 03:10 PM Is it an aftermarket alarm? What kind of alarm is it? It could be a real PITA. Take off the under dash panel and look at the alarm wiring. There should be a few relays that are obviously aftermarket. If you can identify which one is for the starter by testing for voltage when you turn the key, simply take out the relay and connect whatever wires where connected to pins 30 and 87, or 30 and 87a. Some Info (http://www.bfranker.badz28.com/fbody/alarm.htm) | ||
