xmatt
02-20-2003, 10:25 PM
I just bought one and am constructing a system to put it in. What size amp do i need? the speaker is rated at 1000watt, with 300watt continuous power.
Thanx
~Matt
Thanx
~Matt
10W6 Questionsxmatt 02-20-2003, 10:25 PM I just bought one and am constructing a system to put it in. What size amp do i need? the speaker is rated at 1000watt, with 300watt continuous power. Thanx ~Matt firebirdude 02-20-2003, 11:58 PM continuous power (RMS) is the only power that matters.... What type of box is it going to be in? Shoot for a 400WRMS amp. xmatt 02-21-2003, 06:25 PM ty is going into some type of stealthbox. It should have an area of .5-.6, which should be sufficient. I only wish I could get one for less that $100 seeing as how I only spent 90 on the speaker. Do you have a specific amp that I could look the specs up for so that I would have a good idea what I am getting into? I am a real nOOb when it comes to audio stuff. Thanx, ~Matt Originally posted by firebirdude continuous power (RMS) is the only power that matters.... What type of box is it going to be in? Shoot for a 400WRMS amp. firebirdude 02-21-2003, 07:37 PM First thing you should know is that the whole W6 line comes with dual 6 ohm voice coils. If you are only using one subwoofer, you will want to wire the coils in parallel. This will present your amp with a 3 ohm load. So you will want an amp that puts out 300-400WRMS at 3 ohms. I only wish I could get one for less that $100 seeing as how I only spent 90 on the speaker. Does that mean that you want to spend $100 on the amp? If so, your gonna have some trouble powering your sub to it's fullest. One of the best bangs for the buck right now is the JBL BP600.1 (http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3009109568&category=18797) This will output over 600WRMS into a 2 ohm load. Since you will be running at 3 ohms, probably around 400WRMS. xmatt 02-22-2003, 04:40 PM Thanx so much firebirddude. I guess it is gonna have to wait till my birthday. ~Matt | ||
