how do i remove 4th gen transam foglight ?
Old Feb 20, 2003 | 10:50 AM
got_hp?'s Avatar
buld went dead.......i have the t/a front end with two round foglights. there is only one screw above the foglight (probably for adjustment of the angle).........after i unscrewed that, the light still wont pull out.
there is no access from bottom or anything.
should i yank on it harder? i dont want to break anything.
Old Feb 20, 2003 | 10:58 AM
c5formetoo's Avatar
you need to take the lower black panels off that allow you access to the back of the bumper and remove the bulb from the back.you can get them just take your time
Old Feb 20, 2003 | 11:00 AM
Cam94Z28's Avatar
One of the fog lights on my 94 Z28 also burned out, and I, too, would like to know how to replace it. I believe all the screws on the underneath panel need to be taken out, but I'm hoping it's more simple than this. I had the panel off when i was installing my K&N FIPK, I should have replaced them then, as a precautionary measure, but oh well.
Thanks,
-David-
Old Feb 20, 2003 | 12:36 PM
95 Mystic TA's Avatar
I know how to on the bird but not on the bowtie. Once under the car, pull out the little plastic screwd and then un bolt the 1 or 2 bolts holding the "foot" of the foglight bracket in. Pull out the old bulb which might be a little tight, mine both were, and thats it.
Old Feb 20, 2003 | 12:54 PM
Cam94Z28's Avatar
95 Mystic TA,
Sounds Simple enough Thanks, I 'll have to give that a try.
Thanks,
-David-
HOFFICER
Apr 6, 2020 10:36 AM
PROJECT X
Apr 17, 2015 12:13 AM
ad356
Apr 11, 2015 11:12 PM
