low coolant light
Old Feb 18, 2003 | 03:36 PM
bryanbennett44's Avatar
low coolant light
the low coolant light stays on even though the radiator and reserve tank is completely filled. Any ideas? All help is appreciated.
Old Feb 18, 2003 | 03:45 PM
It's a common problem. You can try to clean it, just replace it or you have the option of just unplugging it to kil the lamp on the dash. Unplugging it won't affect anything but the lamp. The sensor is not tied to the pcm.
Old Feb 18, 2003 | 03:46 PM
Dr.Mudge's Avatar
Have you bled the lines? Are you running 5-10% coolant minimum? If both of these are a yes, then you may have a dead/dying sensor in the water pump, some people claim to clean them off with some success.
Old Feb 18, 2003 | 03:47 PM
RamAir95TA's Avatar
If you do choose to unplug it, don't forget to check the level periodically.
Old Feb 18, 2003 | 03:49 PM
ibanez6rg's Avatar
Mine also came on and I checked the level and it was OK. It finally went off about a week later and after that the damn thing overheated and spit all of the coolant out of the filler cap
Got it flushed and haven't had a problem since
Old Feb 18, 2003 | 04:17 PM
where is and what does it look like so i can try to clean it off and/or unplug it? Can i get it replaced?... how much?
P.S. Im running 50% coolant.
Thanks.
Old Feb 18, 2003 | 04:25 PM
ibanez6rg's Avatar
Look at Rob's tech page and it will show you where it's located. It's right under the radiator cap.
Old Feb 18, 2003 | 06:27 PM
atljar's Avatar
Right under radiator cap. It is a little flat square looking thing. About 2in x 2 in. Its hled in with a metel clip. If you remove the battery it is cake to get to it.
Old Feb 18, 2003 | 08:28 PM
Dr.Mudge's Avatar
3 coolant sensors, gotta love the confusion.
Old Feb 19, 2003 | 01:34 AM
-- thanks guys
Old Feb 19, 2003 | 07:17 AM
teke184's Avatar
gm parts direct
part number 10096163, think it's about $30 with shipping.
now i stopped and asked Discount Auto once and they said they had one for around $9....i was a bit skeptical. i didn't buy it since i didn't have the cash at the time. but it's worth lookin into.
calaban
May 18, 2020 06:43 PM
silvermansteve
Mar 4, 2015 05:02 PM
MattFick
Feb 15, 2015 10:16 PM
Jan 23, 2015 01:13 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
