Stock bottom end, lt1 headed car, Can I get it to 400rwhp+, need opinions on set up
Old Feb 17, 2003 | 10:20 PM
stik6shift93's Avatar
Ok here's the deal I've got a bit of money saved up and have been looking at going with some ported stock heads and a cam. Basically I want to get as much power out of it as possible and still be able to drive it on the street without problems. I've been thinking of a custom grind something like a 234-238@.58lift with some steep ramp rates. If I get a good port job will I make it? If you have opinions on a setup that'll get me there let me know, also its a must that I keep my stock heads. Thanks Brad
Old Feb 17, 2003 | 10:23 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
the best port job in the world wont help you if your heads and cam dont match up.
I say 6psi, blower cam, heads by lloyd.
call combo up- let them do the thinking
I dont know if id want 500hp on a stock bottom end though...
just a "when" question at that point.
Old Feb 17, 2003 | 10:24 PM
Smokn '94 Z's Avatar
Lightbulb Re: Stock bottom end, lt1 headed car, Can I get it to 400rwhp+, need opinions on set up
Well I am sure you could get close since you have a 6 speed. If you had an auto I would say 400 RWHP NA is not going to happen. Even with the M6 it will be tough but some people have done it.
Good Luck...
Old Feb 17, 2003 | 10:41 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
400rwhp without heads? It's possible, but I don't think you want to run in stock eliminator
If you want to make alot of naturally aspirated HP, than you will need to spend the $$$ on some good cyl heads.
Old Feb 17, 2003 | 10:48 PM
stik6shift98's Avatar
ya u can make 400 rwhp...maybe in your wettest dreams....
i would get stage 2 heads and a 230 cam then add some juice
Old Feb 17, 2003 | 11:31 PM
6Speed's Avatar
400rwhp is very possible with the right head/cam/bolton combo.
My car made 371rearwheel with homeported heads/stock untouched valves, stock TB, cc306 cam, Hooker LT's, cutout, elec waterpump, 1.6 rockers (that were terribly loose, and rubbing on the valvecover supports)
Hopefully my car will hit 385-390 with the valves correctly adjusted, bigger TB, and the supports being cut out of the valve covers. I'm sure I was getting false knock from the rockers hitting the valve covers.
400 should be easy with a stage 2 professionally ported heads, and correctly adjusted valves. But every car is different.
Zack
Old Feb 17, 2003 | 11:45 PM
jakef2003's Avatar
www.advancedinduction.com
I need to call Phil, and get my order in.
Old Feb 18, 2003 | 12:01 AM
chesee48's Avatar
hmmmmmmm Bradley, what are u up to...hmmmmmmm
Old Feb 18, 2003 | 12:07 PM
I remember a post a while back of somebody making like 421 at the wheels with stock lt1 heads(i think they where ported by skaradom) and a custom grind cam of undiscloused specs(it was cc306ish from what I heard), threw shorty headers. Does anyone remember this? Chesee I'm just trying to give these ls1 guys a run for there money............and you too once your cars finished
Old Feb 18, 2003 | 12:15 PM
INTMD8's Avatar
I thought you meant STOCK lt1 heads as in unported.
If you are going to do ported factory LT1 heads, and a cam, than you can get 400+ rwhp with the right combination.
Old Feb 18, 2003 | 02:24 PM
So can anyone recommend a heads and cam setup to get me there?
Old Feb 18, 2003 | 02:34 PM
97Z-M6's Avatar
let these people do the thinking for you.
Old Feb 18, 2003 | 02:51 PM
Mindgame's Avatar
With the right cylinder head work you should be able to make 400 rwhp (350 ci) with a something like the XE224/230 on a 112 degree LSA. That's assuming a ~14% drivetrain loss (T56) which according to some of the data I've seen is a bit on the high side.
-Mindgame
Old Feb 18, 2003 | 02:54 PM
chesee48's Avatar
U have emmisions still dont u??
Old Feb 18, 2003 | 03:51 PM
Dr.Mudge's Avatar
If you have emissions to consider, then there could be a problem getting there NA on a stock bottom with a hyd cam. Otherwise, it can and has been done, there was a 93 that made ~400 RW with stock heads even, 244/244 -114 solid roller though. I think his car was toasted some time back Vulva is his member name, JimS knows him, but I'd go with heads if you can afford it. Spend a few months thinking about your options and putting the dough/parts together.
If you can get it tuned, you'll see 400+ with the right setup.
