Do I need a 52mm or 58mm throttlebody for my new setup??
I am going to be doing my heads/cam swap in the next few weeks, and I have been trying to decide on what throttlebody to get. I will be going with fully ported heads that flow 265/192 @ .600, Comp XE 236/242 on a 112, fully ported intake, long tubes, 30 lbs SVO's, and tons of bolt ons that will be installed at the same time. It is going on a stock shortblock for now, and I have plans for a stroker motor in the future. Right now I am trying to decide if I need the 58mm, or stay with the 52mm. I know the 58mm is good for blower motors and all out race setups. Anyone have any opnions on which one I need??
Brian
Brian
Thanks for the opinions so far, but is there anyone out there that has used both sizes to compare with. I was thinking about just getting the car running with the 48mm, and then going from there. I have just heard that the 58mm is over kill for anything less than a stroker or blower/nitrous car. Any more help would be appreciated.
Brian
Brian
i'm running the stock 48mm w/ P.P. heads and the XE230/236
afaik, rskrause is/was running the stocker w/ his 700+ rwhp 383...
i've yet to see definitive dyno results stating the limitations of the stock tb...
Brian
Brian
Originally posted by Fear The Z
question on your wheels....are they 18x9.5's all around?
[i]You should start of with the 48mm stocker & then go bigger & tell us if there is any gain to be had. This would be a good learning expirience for all of us on your account...[/B]
, I would do back to back tests on the dyno to see if you actually gain any power. Well enough for now, its off to work.Brian
BTW WJH.... How does your car run with this setup?
This is definitely an interesting debate. One that I'm curious of also. I still have my stock throttlebody in the attic, and a 58mm is on the way which I bought used(hopefully
), the 52mm is on the car now. When the weather clears up around here(probably may or june w/all this snow) I'll take my car to the dyno again and find out and I'll post the results
Hopefully in the next few weeks we will decide this debate.
I have both a 48mm and 52mm.
The car is going to get dyno tuned on my new setup.
XE 230/236 on 111LSA & PnP Combination Motorsport Heads.
Me and Ed Wright were talking about this very same thing and we are going to start off with the 48mm and than put a 52mm on it to see if its going to make a differance or not. I also have 30lbs injectors on the car as well.
