FS 21 inch NEC XE21 Monitor $200 OBO
This is a really nice like new monitor, I've been using it for a couple years with no problems whatsoever.
Whoever buys it MUST pick it up at my house, its way too big and heavy to ship.
I have the monitor set at 1152x864 @72hz but it will do up to 1280x1024@60hz
Here are the specs copied from the NEC website:
you can email me at jim@krif.com for more info.
Picture Tube 21" (19.8" viewable image size)
flat square technology high contrast CRT 1733 mm radius
90 degree deflection
0.28 mm trio dot pitch,dot type matrix
medium-short persistence phosphor
anti-static coating
Invar shadow mask with Litz wire yoke OptiClear surface.
PC Compatibility
640 x 480: VGA 60, 72, 75 Hz vertical refresh
800 x 600: 56 to 76 Hz vertical refresh
1024 x 768: 8514/A, XGA, XGA-2 at 75 Hz vertical refresh
1024 X 768 non-interlaced: 60 to 76 Hz (recommended)
1280 x 1024 non-interlaced: 60 Hz vertical refresh
Macintosh Compatibility
640 x 480: 67 Hz vertical refresh (40 DPI)
832 x 624: 75 Hz vertical refresh (57 DPI)
1024 x 768: 75 Hz vertical refresh rate (70 DPI)
1152 x 870: 75 Hz vertical refresh (72 DPI)
Synchronization Range Horizontal: 31 kHz to 69 kHz
Vertical : 55 Hz to 120Hz
Max Video Bandwidth 85 MHz
Active Display Area (Factory Setting) Horizontal: 390 mm, 15.4" (Dependent upon signal
Vertical: 293 mm, 11.5" timing used)
Active Display Area (Full Scan) Horizontal: 402 mm, 15.8" (Dependent upon signal
Vertical: 381 mm, 11.9" timing used)
Input Signal Video: Analog 0.7 Vp-p/75 Ohms positive
Sync: Separate sync TTL level
Horizontal sync positive/negative
Vertical sync positive/negative
Composite sync TTL level positive/negative
Composite Sync on Green 0.3 Vp-p
Display Colors Analog input: unlimited colors (Dependent upon video card)
Power Management Intelligent Power Management (IPM) system, EPA Energy Star, NUTEK based upon VESA DPMS 4 states.
User Controls Power, Degauss, brightness, contrast, sync switch
horizontal size, horizontal position, vertical size,
Vertical position, AccuColor, basic geometry,(sides
in/out; left/right balance; tilt; align), advanced geometry
(top: in/out; bottom: in/out; left/right balance), GlobalSync, OSM location adjustment, OSM turn off time (10, 20, 30,
60 and 120 seconds),display mode (current mode;
H. Freq.; V. Freq.; H. Pol;V. Pol), language select
( English, German, French, Spanish, Italian, Swedish), vertical linearity(center, top/bottom)
Advanced Communications Plug and Play
Signal Cable Captive 15 pin mini D-Sub connector
Power Supply 100 to 120 V AC, 50/60 Hz
Current Rating 2.1 Amps, 120 watts, 410 BTU
Dimensions: (HxWxD) 512 x 519 x 572 mm/20.2 x 20.4 x 22.5 inches
Weight 33.7 kg/74.2 lbs.
anti-static coating
PC Compatibility
Brian29575
Feb 15, 2015 03:59 PM
