cold start internal motor noise help
Old Feb 17, 2003 | 12:51 AM
justforfun's Avatar
sound like it is the oil pump or oil pump drive gear in the back of the motor, but it only makes noise for a minute or two when it is cold outside. Has anyone had this happen?
both parts only have about 1000miles b/c i chewed up the driven gear and had the pickup disk break off the pump.
any ideas?
Old Feb 17, 2003 | 08:37 AM
Josh Z95's Avatar
On start-up I do have some loud kinda whin noise, but only when cold and only lasts for a minute of so.....
Old Feb 17, 2003 | 08:56 AM
DDZ/28's Avatar
Lately I've been getting the same thing. The colder it is the longer it lasts...no more that a couple of minutes though. I tried finding out where it was coming from and could swear it's the alternator.
Makes me nervous everytime I hear it
Old Feb 17, 2003 | 09:51 AM
Hyperspeed97z28's Avatar
I get the cold WHINE for a min or two been below zero in the am here though..
Old Feb 17, 2003 | 10:58 PM
Josh Z95's Avatar
Does anyone know what is creating this sound, how to fix it, or if it is a bad thing. Doesn't really sound like a good thing though....
Old Feb 18, 2003 | 12:30 AM
justforfun's Avatar
i am in SC so when i say cold i mean below 45F or so. I thought it was the alt for a sec but i am positive mine is in the back of the motor. It is loud enough where i could detect it even witht the exhaust noise while i was inside the house.
Just brainstorming, could it be the cam walking to far back?
When i get a chance i will look for metal on my magnetic oil drain plug.
DDZ/28, if you think yours is the alt take off the belt and see if it goes away.
Old Feb 18, 2003 | 07:28 AM
Seta's Avatar
Totally 100% normal. My Z has been through 8 winters and on cold days that happens everytime. The key is also harder to insert on a cold day. Just the way it is, no harm no foul.
Old Feb 18, 2003 | 08:44 AM
red's Avatar
red
You may be hearing piston slap. It's very common on the LS1's and some LT1's will have it also. When it is very cold the piston will shrink more than the block and will make noise untill it warms up and expands back to tolerance. That is why you hear it only for a min or two. It is also very hard to tell where the sound is comming from since it is basically comming from all eight cylinders. If you are familiar with the sound you will hear it right away.
Old Feb 18, 2003 | 09:08 AM
CODY BEHNKE's Avatar
Same here, After having a LT1 for two winters you get to know the noises they make when it's -20 outside.
LeftoverChinese
Jan 14, 2024 03:03 PM
Gtpguy
Jan 26, 2015 04:50 PM
ChrisFrez
Jan 18, 2015 08:05 AM
jj71787
Dec 30, 2014 02:15 PM
