Ignition Modifications???
Jay-mak
02-16-2003, 10:55 PM
What could I do to boost my ignition performance? Would I see any benefits? What type of Performance parts would I need?
I am open to any suggestions!!!!
My ignition at the present time is stock so I figured anything would help....right?
jd13
02-16-2003, 11:02 PM
You could change your plugs and plug wires if you really wanted to.
Upgrading your ignition would not be worth it. You won't see any gains at this point. The stock ignition is pretty good. If you had 150k miles or so, I'd say go for it. Also, if you were running some large doses of nitrous quite often, then it probably wouldn't hurt to upgrade. Otherwise, spend your money elsewhere. I'm no expert, but that's my opinion.
Ghost SS
02-17-2003, 01:13 AM
The stock ignition on the Ls1's kicks ass!! Don't mess with it....don't waste your money on new plug wires. Our stock wires are 8mm and are only a few inches long so there is hardly any resistance.
amood
02-17-2003, 04:54 AM
I went with Taylor Thundervolt (10.4 mm) wires, and Bosch Platinum +4 plugs just bescause I had the $ to throw at them.
Jay-mak
02-17-2003, 02:22 PM
Thanks guys!!! I really appreciate the Info. I guess I will just spend my money else where.....maybe somes headers from SLP?!?
