lt1 rebuild
Old Feb 16, 2003 | 08:35 PM
nas-T-72z's Avatar
lt1 rebuild
well the lt1 in my 95 z28 just took to burning oil. so a rebuild is needed. did , cam, headers, cai,exhaust, about a yr ago. normally i would take this on as a weekend project but... dont have the time nor tools right now. so my question is what is a good guesstimation at what a shop would charge to pull and rebuild my motor and reinstall it. or what have any of you paid for one? thanks in advance
Old Feb 16, 2003 | 08:38 PM
TCAL95Z's Avatar
I'm not sure about the cost of a rebuild but I've had guys here in AZ quote $600 to $800 for the engine swap.
I'm curious, how many miles are on your engine and is it smoking?
Tom
bad96firechikin's Avatar
Machine work on my block was about $600...now that was to bore over, torque-plate hone, vat, install new cam bearings and freeze plugs, and the align bore and align hone for my splayed 4-bolt main caps, and tap the bolt holes. But that was just the machine work on the block for my rebuild. Total I'm close to $4000...and I'm doing all the work myself.
Old Feb 16, 2003 | 08:40 PM
However, I'm goin' with a lot of expensive parts I didn't hafta use either. If you're wanting a stock rebuild you won't be out too much. I figure why have the motor out just to put a stock one back in though.
Old Feb 16, 2003 | 08:44 PM
nas-T-72z's Avatar
well it was rolling up on 125.000 miles and the opti was acting funky . bad opti bearing . and i was doing about 160+ and it detonated and started smoking. a lot of blowby vapor coming from the filler cap. im stickin with a stock rebuild. have my other car for racing. just lookin for a ring n bearing, heads rebuild.
Old Feb 16, 2003 | 09:05 PM
shocktrp's Avatar
Here in NY it;s about:
$2k for bottom end rebuild (355). About $1600 to pull motor & reinstall.
Figure another $700 to rebuild your heads.
Old Feb 16, 2003 | 10:17 PM
TCAL95Z's Avatar
if you just want a basic rebuild you might try the Summit kit.
With forged pistons it's $539. I've never heard from anyone who has used it.
I think $500-600 is about right for machine work
usually about $500 to assemble the engine
Old Sep 5, 2003 | 11:16 AM
cjksflorida's Avatar
Is there anyone out there that has used the Summit rebuild kit, with forged parts. That's what I'm looking to do and that would save a little money
Old Sep 5, 2003 | 11:57 AM
TMDZ28's Avatar
i heard a forged summit rebuild is pretty good. just need to buy a forged crankshaft. i'm planning to use summit rebuild kit when my engine is toast. i will use the forged rebuild kit because i'm using nitrous
Sergio
Jan 27, 2016 04:27 PM
Vinceocratic
Jan 26, 2015 09:26 AM
Not Dave
Dec 11, 2014 06:32 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
