Where does the pipe plugged passage in the intake lead to?
Old Feb 16, 2003 | 01:22 PM
LTOne4Fun's Avatar
The one in the front bottom of the intake under the TB opening?
Old Feb 16, 2003 | 02:44 PM
96z's Avatar
96z
That goes to the EGR valve...on the drivers side of the intake.
Old Feb 16, 2003 | 03:10 PM
ZLT195's Avatar
Maybe this will help
Here is a visual
Old Feb 16, 2003 | 04:22 PM
Robbie's Avatar
The only one I can think of that you're talkin about is the coolant line that runs through the bottom of the throttle body. The tube coming out of the driver side of the throttle body goes to the passenger side of the radiator right by the radiator cap. The left tube going into the TB should just be like a 3in 90 degree angle tube that connects to the metal tube that runs down the passenger side of the intake manifold. Not exactly sure which pipe you talkin about but those might be it.
Old Feb 16, 2003 | 04:27 PM
RamAir95TA's Avatar
He's talking about the pipe in this pic ON the intake manifold, directly behind the waterpump thermostat neck and below the throttle body plenum.
onefastgta
Mar 19, 2015 10:10 AM
MadMav
Feb 6, 2015 11:02 PM
Alex Barnes
Jan 24, 2015 10:21 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
