Troubleshooting help needed.
Old Feb 16, 2003 | 01:13 PM
wilsoncj6's Avatar
Question Troubleshooting help needed.
Here the email I got from my dad. His is a 93 Z28.
"Brett,
Here's the situation with the car.
Prior to this morning the car has been running fine. This morning when I turned the ignition key on, the fan that helps cool the engine when it is getting hot came on immediately. I started the car and it will not idle below 2,000 rpm's (normal is 6 or 7 hundred). I have turned the engine off after driving it for a while and the fan comes on immediately and the idle stays at 2,000 when I start it again.
FYI: A month ago the computer was replaced because it was not working properly and as a result one of the injectors would never close. Since then until this morning, everything seems to have been fine. "
If this has happened to you before or you got any ideas of what might be wrong, please let me know!
Old Feb 16, 2003 | 01:15 PM
ollie-99's Avatar
it sounds like you car is running in Open Loop
Old Feb 16, 2003 | 04:11 PM
wilsoncj6's Avatar
What would cause that? The computer going bad? This is the 3rd computer they've had in that car in 4 months.
Old Feb 16, 2003 | 04:24 PM
Robbie's Avatar
Sounds like the same problem as before. Maybe something is making the computer go bad. Wiring shortage somewhere maybe?
HibachiZ28
Nov 6, 2015 12:53 AM
jbert55
Oct 31, 2015 03:52 PM
tommalcolm
Sep 11, 2015 03:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
