Quick CC305 question
Old Feb 12, 2003 | 09:32 PM
Grn96Z's Avatar
ok, are these good enough for the cc305?
Comp Cam 983-16 valve springs
Comp 751-16 retainers
Comp 613-16 locks
Am I missing anything except for the 1.6 rr?????
Old Feb 12, 2003 | 10:24 PM
Grn96Z's Avatar
These are the recomended springs but I read that they dont fit, anybody know if they will work or not???
Old Feb 12, 2003 | 11:34 PM
stik6shift93's Avatar
Don't know the ansewer to your question, but what I can tell you is that comps customer service is pretty great. Give them a call and they can tell you what you need.
Old Feb 13, 2003 | 12:16 AM
Lisa33's Avatar
The 983 didnt fit in my engine. This is a part of a mail from Comp:
The correct spring that needs to be used is our 981-16 valve spring. You will have to remove the damper from these, but they will fit over your stock locator. The catalog does list the 983 spring, but it will not fit your locator and I do not make one for the LT1 engine. The 981 spring can use the 742 retainer which is 7 degree or the 950 retainer which is 10 degrees.
I got the 983 and i had to let a mech shop make new locators to me.
cheeper/easyer than shipping it back from sweden.
Old Feb 13, 2003 | 12:40 AM
97bowtie's Avatar
I believe you will have to have the heads machined for those springs to work. I have the Crane 10308 springs - they are dual coil and are good to .600" lift w/no machining required. Something to look into.
Old Feb 13, 2003 | 06:06 AM
Lisa33's Avatar
No machining needed on the heads only new locators/shims the OD is stock size but The ID is a little smaller than stock springs.
But if i had this info from the begining i should have order the crane 10308-1 set insted.
Old Feb 13, 2003 | 10:41 AM
Grn96Z's Avatar
Thanks for the replys. They really helped out. If I could get these parts cheap enough though should I just get them and have new locators made?
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
Jan 23, 2015 01:13 PM
97bowtie
Aug 25, 2002 11:00 PM
