best heads for a 396?
Old Feb 11, 2003 | 08:26 PM
94droptopz's Avatar
whats the best heads to buy for a 396 and stay under $2000? would it just be best to get a real good port job on my stock heads or some afr's or what? thanks
Old Feb 12, 2003 | 07:15 AM
IDOXLR8's Avatar
If you do a search you will find alot of useful info on this subject. There are many options ou there. Are you going to stay NA with the 396??
Old Feb 12, 2003 | 10:37 AM
GhostZ's Avatar
You may want to check out some of your local race shops that have a good reputation for headwork.
I'm having a local Pro Stock head builder port mine for a third of the price of buying a new set of CNC'd heads....of course it helps that I work at the track so he's cutting me a good deal.
Old Feb 12, 2003 | 01:48 PM
dabear95's Avatar
From the information I have gathered, a 396 with a 306ish cam will run out of steam at around 4,500 RPM with stock LT1 heads...
Jason
Old Feb 12, 2003 | 02:20 PM
BlkScreaminMach's Avatar
Thumbs up Spend the money, GET AFR's!!
If your doign a 383, i would say go for P&P'ed heads, im still using mine for my build up, but if i do any boost (blower or Major N20) Im gong to step up for AFR heads. FOr a 396 you need heads and a cam that flow the air nicely.
DO you have emissions?? CUs if you did, skip the cc306 and get a custom grind cam that has HIGH lift, but low overlap/duartion and you will pass emission GMHTP project car "Thunderchicken" is a prime example that it isnt the displacement that kills emissions its the inefficency of the cam. Allowing the unburnt fuel to go out.
transam_388
Mar 15, 2015 11:53 AM
Roadie
Feb 16, 2015 10:34 AM
pimpss96
Feb 12, 2015 01:28 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
