Details on what wires go from MSD rpm switch to TACK & Computer
Old Feb 9, 2003 | 11:31 PM
therealmagyver's Avatar
I need details on what wires run from the MSD switch to the TACH and COMPUTER. Does anyone have links or a diagram?
Old Feb 9, 2003 | 11:34 PM
stik6shift98's Avatar
call up a nitrous company
stik00 has it done he probably remembers or can help you out
Old Feb 9, 2003 | 11:41 PM
Thanks. I will do both.
Old Feb 10, 2003 | 12:03 PM
Mikael's Avatar
Run the MSD in 4 cyl mode (LS1, right?), which means you cut the little loops.
Ground = Ground
12V+ = Wire to 12V+ when ign is on
RPM Feed = #10 or #12 on the ECU, check ls1.com FAQ
Ground Signal = This is what the Switch sends to turn on the relays to fire the juice.
Old Feb 10, 2003 | 12:50 PM
stik6shift00's Avatar
no diagram but i have did my tach to a white wire on the computer in the upper left side of the engine bay...i think there is one in the back of the cluster also
Old Feb 10, 2003 | 10:58 PM
I've found this.
http://www.ls1.com/enginetorques.htmPCM Pin assignments
Old Feb 11, 2003 | 09:46 PM
that last post seemed to help a bit
RUENUF
May 25, 2016 08:10 PM
armedtrigger
Feb 24, 2015 08:30 PM
Jazsun
Dec 29, 2014 12:14 PM
Jul 4, 2005 05:00 PM
