Lowering Kits, Suggestions
Ferocity02
02-09-2003, 02:48 PM
I need some suggestions on a lowering kit for a 99 Z28. I have my eye on this: http://www.thunderracing.com/index.cfm?fuseaction=subcategory&subcategoryid=1068 It's the lowering kit about 2/3 of the way down. I'm just curious if this is a good one. Should I get some shocks to go along with it? Also, do you think it will allow enough room for 18's and rubber? Thanks
stik6shift98
02-09-2003, 05:52 PM
id only go with a 1inch drop
get mac
my sponsor has some good springs check it out in the link in my sig
stik6shift93
02-09-2003, 05:53 PM
My buddy has macs and they're great,.
stik6shift99
02-09-2003, 06:24 PM
will lowering springs help with traction or make it worse or keep it the same
nikkev
02-09-2003, 07:18 PM
Lowering your car will make you lose traction.In order to get it back you need some LCA re-location brackets.
Kevin
stik6shift93
02-09-2003, 07:28 PM
In the corners you'll gain traction, in a straight line you usually lose it due to higher spring rates thus less weight transfer.
stik6shift98
02-09-2003, 07:32 PM
is it hard to put relocation brackets on....i just remembered they're sitting in my garage.....bmr bolt on kind.....
Ferocity02
02-09-2003, 09:39 PM
I was gonna get those, how are they hard to put on?
stik6shift00
02-09-2003, 10:40 PM
dont lower it too much...my cars exhaust piping hangs really low...and i bottom out alot..i did yesterday w/ 4 people in the car.my friend behind me said there were sparks everywhere and though he saw somehting fly out..so be carefull! dont lower to much..this was also on a ****ty road at 120....that might have helped out:)
horseplay
02-10-2003, 08:49 AM
I have my eye on this....I havent heard anything about it yet??
http://www.rksport.com/rkstore/dept.asp?SelectPrimary=Camaro&SelectSecondary=1999+5.7&mscssid=&x=25&y=8
anyone???
10% off this month on suspension Im pretty sure
stik6shift98
02-10-2003, 10:16 AM
ground control adj coilover?
the link doesnt take you to exact item
rksport is gay like that
:D
horseplay
02-10-2003, 10:44 AM
yeah..thats it....anyone heard anything about that? ...sounds like an ideal setup for me
stik6shift98
02-10-2003, 01:38 PM
i havnt heard of it b4....i woukldnt get it.... go with something that most fbods have that is prove to be good
2002 NBM Bird
02-10-2003, 02:38 PM
I think your banging problems had more to do with your choice of header. SLPs hang very low
stik6shift98
02-10-2003, 05:08 PM
true....
but even my flps are low as well...
horseplay
02-11-2003, 02:30 AM
about the ground control........its adjustable which sounds great for what I want...I love the look but sometimes I cant have the low car. This system is made by Eibach....Id like to know more. Ill keep searchin around
stik6shift98
02-11-2003, 10:16 AM
thts cool
but id check out something else as well........:D
mac springs
Ryuhei
02-11-2003, 11:28 AM
Talk to Sam Strano at http://www.stranoparts.com Tell him exactly what you want. He'll tell you what to get. He's very patient and thorough. You could fark yourself and your car of you get the wrong stuff.
stik6shift98
02-11-2003, 10:50 PM
hpa hpa:D :D
EvilDCustoms
02-16-2006, 07:37 PM
yea about the GRound countrol coilover kit, i got it on my 95z and i love it, the ride isn't bad at all, i just put them on cause i had intrax springs and i hit everywhere, now i raised it with the coilover kit and its awesome, rides nicer and still can barely feel any body roll if any, make sure u good sway bars also if u do autox, my next step is shocks cause im still saving up money so i got stock shocks still and it still rides sweet.
