LCAs and Panhard Rod Install
Old Feb 7, 2003 | 04:27 PM
Ernster500's Avatar
Thumbs up LCAs and Panhard Rod Install
Hey Guys,
I'm going to be installing my new BMR LCAs, Relocation Brackets and Panhard Rod.
A couple of questions:
When I jack the car up and put it on stands, do I need to let the rear axle hang? Or do I put it on the jacks?
Also, is there any special tricks I need to know about doing this particular job?
As always...Thanks, in advance!!!
Ernie
Old Feb 7, 2003 | 04:40 PM
Buttercup's Avatar
I let my axle droop and install one piece at a time. Just something about the thought of supporting the weight of the vehicle from a suspension I'll be removing pieces from that scares me
The instructions tell you to do so, don't they?
Old Feb 7, 2003 | 04:49 PM
KCFormula's Avatar
When I put my LCAs on I let the axle hang and then put the jack under it and pushed it up until the holes lined up. Made the job easy as pie!
Old Feb 7, 2003 | 06:38 PM
Ernster500's Avatar
They got delivered today, but I haven't been home to open the boxes yet...
That sounds like good advice. Thanks!
E
Old Feb 7, 2003 | 08:20 PM
stik6shift93's Avatar
Quick note: don't tighten down the lcas or panhard rod with the axle hanging, you can put them on with the axle hanging but you need to have the rear suspension loaded before you tighten the bolts down.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
SLIMJIM
Jan 7, 2003 11:06 AM
Skull Leader
Aug 10, 2002 11:01 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
