Okay to re-use head bolts on the LT1???
Old Feb 5, 2003 | 02:44 PM
97 6SPEED Z's Avatar
Hey guys, I'll be doing a cylinder head swap either late spring or early summer, and I'm trying to round up all the parts I'll need before hand. One item of discussion is weather or not we can re-use cylinder head bolts on the LT1 engine. I know the LS1 engine uses "torque to yield" head bolts which are designed to stretch during assembly and cannot be re-used. But what about the LT1 engines??? Is it okay to re-use our head bolts if they clean up well and look good? Has anyone out there re-used your head bolts after a cylinder head swap? Any problems with re-using LT1 head bolts?
TIA for all replys
Old Feb 5, 2003 | 02:45 PM
Ken95Z28's Avatar
I think 96 and above went to torque to yield.
So in your case you would have to get some new ones or switch over to ARP.
Old Feb 5, 2003 | 03:00 PM
All_Z_Way's Avatar
Does anyone have ARP part numbers?
Old Feb 5, 2003 | 04:19 PM
sscott's Avatar
Ken95Z28, I think that all LS1's have torque to yeild bolts. You can use the bolts again on an LT1. I was going to re-use the head bolts for my LT4 conversion but had a change of mind. The head bolt part # is: 0070134-3601 from Jegs, and they are ARP. Hope this helps.
Old Feb 6, 2003 | 01:05 AM
allmotorta's Avatar
Originally posted by ACA Performance
The question is why would you skimp out on something minor?
You were able to afford new heads but no bolts. Do it right.
If the bolts are still good, why not use 'em? I don't like to throw my money away on unnecessary stuff either.
Old Feb 6, 2003 | 01:08 AM
bad95z28's Avatar
might as well try and reuse all of your old gaskets as well. and maybe you can use the same motor oil, just put it back in. why take a chance on something that is real simple to do and not very expensive?
Old Feb 6, 2003 | 01:31 AM
Vader's Avatar
Been there, done that
My 94 had torque to yield bolts in it from factory. I found out while trying to re-use them. Very scary, thinking I had pulled a thread out of the block. Replace them - every time. I used Felpro bolts - smaller hex, flange head style.
Old Feb 6, 2003 | 01:43 AM
Dr.Mudge's Avatar
Interesting info Vader (the band?), I've used mine 3 times on my 94, so far so good!
Old Feb 6, 2003 | 02:42 AM
allmotorta's Avatar
Might as well
Old Feb 6, 2003 | 06:53 AM
GUMP's Avatar
NO, NO, NO!!
A new set of bolts from GM is extremely cheap. I broke a head bolt during tear down at an IHRA race last year and had to pull the head back off. I used to use them twice before tossing them. Now I run ARP.
Daren
Old Feb 6, 2003 | 08:02 AM
95 Silver TA's Avatar
Do yourself a Favor and replace those bolts. I was always told that our stock head bolts do stretch with added stress on em. I would not take the chance. Just get a set of stock replacement if they are cheap or the head bolts from ARP OR if you have a 160.00 laying around get the Head Studs from ARP. The head studs provide a much better clamping force and I was told my ARP that the Studs can be used over and over again. Also the new studs have an Allan key etched in the top of the stud so it makes it much easier to remove your heads with these allan keyed head studs (Easier than it use to be before with the old head studs without the allan key)
Hope that helps,
Old Feb 6, 2003 | 09:21 AM
tubby's Avatar
torque to yield--- replace them! or take the risk. you might get away with it time after time but what if you don't? is it worth it?
Old Feb 6, 2003 | 01:46 PM
First off, thanks to all who have replied. I didn't think I'd set off such a controversy with such a simple question
Just for your info, the heads I'll be putting on are stock LT1 cores which I paid $300 for off this board. I will of course have about 50 hours worth of porting and polishing time "invested" in them when it comes time to install them. But, for the guys at ACA Performance, yes when you've only paid $300 bucks for the heads, another $60 bucks to replace perfectly GOOD bolts, does indeed make a difference. You guys will have to trust me on this one but I've done many an engine rebuild on other non - LT1 engines and the question is really simple, if the engine does NOT use "torque to yield" head bolts, and a thorough cleaning and inspection of the bolts does not show ANY problems, then you are just throwing money away by buying new fasteners. Remember, NEW head bolts will not make you car 1) go faster, 2) look better, 3) get better gas mileage, 4) smell better, etc. etc. etc. (you get the point here right?). In short, NEW head bolts if they are NOT needed, will do NOTHING for you car.
The peace of mind I will get in re-using my head bolts, (if they are NOT torque to yield fasteners), will come from the thorough cleaning and inspection I will give them, and the knowledge that they have been "proof tested" by already having been used in this application
Nonetheless, thanks to ALL who replied
Old Feb 6, 2003 | 01:59 PM
Dr.Mudge's Avatar
I'm not saying to try it yourself, but Jordon has re-used some Fel Pro headgaskets multiple times
Old Feb 6, 2003 | 03:26 PM
GUMP's Avatar
The part number for the factory bolt package is 12495499. I last purchased a set in 2002. The list price was $26.07 and I paid $22.16.
Daren
